    Duet2 with 2.0 RTOS looses Duex5 on reset
    • gtj0
      gtj0 last edited by
      It looks like if you reset (M997, M999, etc) a Duet2 with the 2.0 firmware and a Duex5, the Duet2 doesn't recognize the Duex5 when it comes back up. The hardware string just says "Duet Ethernet 1.02 or later" instead of "Duet Ethernet 1.02 or later + DueX5" and commands to motors on the Duex5 are ignored. The only way to get it back is a power cycle. Even rolling back to 1.21 still needs a power cycle to get the Duex5 back.
      Dougal1957 1 Reply Last reply Reply Quote 0
        Thanks for your report. I will try to reproduce this.
        • whosrdaddy
          whosrdaddy last edited by
          Cannot reproduce this on my setup.
          Maybe a problem with the flat cable?
          gtj0 1 Reply Last reply Reply Quote 0
          • gtj0
            gtj0 @whosrdaddy last edited by
            @whosrdaddy said in Duet2 with 2.0 RTOS looses Duex5 on reset:
            I would think that if it were a cable problem the issue would occur on 1.21 as well and it doesn't.
            • Dougal1957
              Dougal1957 @gtj0 last edited by
              @gtj0 said in Duet2 with 2.0 RTOS looses Duex5 on reset:
              But you said that rolling back to 1.21 still requires you per cycle it to get it back is that not the same
              • gtj0
                gtj0 @Dougal1957 last edited by
                @dougal1957 said in Duet2 with 2.0 RTOS looses Duex5 on reset:
                Ah, sorry for the confusion. Let me clear. When running 2.0 I have the issue. If I roll back to 1.21 WITHOUT A POWER CYCLE I'll still have the issue until I do a power cycle. Then everything's normal on 1.21. This sounds like a 2.0 firmware issue that puts the hardware in a funky state that can't be recovered without a power cycle even if the firmware is downgraded.
