    My Delta Printer DeltaStar 2
    My Duet controlled machine
    1123
    • flopo76
      flopo76 last edited by flopo76
      https://www.youtube.com/watch?v=yNni29bLQcg&t=2s
      ![alt text](imag0_1529761644665_20180505_15m0230.jpg e url)0_1529761718556_IMG_20180j617_101452.jpg 0_1529761769009_IMG_201806gf17_101431.jpg
      Work in progress.....
        Nicely done. Can you provide some more details?
        • Barracuda72
          Barracuda72 last edited by
          nice Build.
          With what cable you solved the Cable Problem at the effector? I like your solution.
          Is that already the print bed in the middle? or only the heat bed? and why you probe outside print area then?
          flopo76 2 Replies Last reply Reply Quote 0
          • Danal
            Danal last edited by
            Motors and such on top!!! Good man!!!
            • flopo76
              flopo76 @Barracuda72 last edited by
              @barracuda72 In the middle there is only heatedbed, the printing surface is bigger. I have to put the aluminum plate under the glass
              • flopo76
                @barracuda72 https://www.distrelec.it/it/spiral-grounding-cable-con-schermatura-12-conduttori-12-x0-14-mm-the-best-solution-spiraflex-pur-cy-sp-dsr-014/p/15557034
                • Barracuda72
                  Thx for the answers
                  I don't know how much bigger the print bed will be but you will maybe have problems because the print surface in the middle will be much hotter than outside.
                  The print bed will probably bulge
                  hmmm..12x0,14mm² wires..just count and i need 12 wires..but..0,14mm² seems a bit to small for the heater.
                  max current for a 0.14mm² ist 3A ..if you have a 40W heater it needs 3.3A..even with a 30W heater its aleready near limit. How did you solved this? 24V?
                  I have to change my delta to 24V
                  flopo76 1 Reply Last reply Reply Quote 0
                  • flopo76
                    @barracuda72 I used the shielding for the negative and two wires for positive. my printer is powered by 12V
