    Post Process Gcode with macro
    1.1k
    • Adamfilipundefined
      Adamfilip
      Is it possible to post process Gcode files with a Macro
      I would like to search for Layer 2 and insert some custom GCode, using a macro
        Most slicers have a facility to post process the output.
        • T3P3Tonyundefined
          T3P3Tony administrators
          I found this for Cura:
          https://ultimaker.com/en/resources/20442-post-processing-plugins
          www.duet3d.com
          • deckingmanundefined
            deckingman
            For something simple like adding gcode commands at layer 2, I use notepad++. For more complex things like changing the mixing ratio every other layer throughout the print, I write little Python scripts. Dunno if that helps........
              Adamfilip
              trying to avoid manual file editing, if i can
              • T3P3Tonyundefined
                T3P3Tony administrators @Adamfilip
                @adamfilip yeah @deckingman's python scripts are a good option for more complex post processing.
                www.duet3d.com
                  Adamfilip
                  ok going to have to look into it. Never written Python, never been much of a Coder 🙂
                    deckingman @Adamfilip
                    @adamfilip said in Post Process Gcode with macro:
                    Me neither. I'm a soon to be pensioner, a mechanical engineer by training and a carpenter by career choice, but I managed to pick up enough to do what I need to - via Google and YouTube mostly.
