    Macro for Calibrating Z Probe - Issues
    1229
    • brunofporto
      brunofporto last edited by brunofporto
      I am writing a macro to automate and simplify the Z Probe calibration as described at:
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      For now I am doing this, manually, at the console:
      G28 ; Home all axis
      G0 S0 X149 Y140 F6000 ; Move nozzle to the cendter of the bed
      G92 Z15 ; DANGER! Now the nozzle can crash the bed!
      M291 P"Please move the nozzle until it touches the bed or reference." R"Setting Zero" S3 T0 Z1 ;
      G92 Z0 ; Set the new Z=0
      G0 S0 X119 Y140 Z5 F6000 ; Move probe to the center of the bed and z=5mm
      G30 S-1 ; Report the probe height
      I am having two issues:
      First at the M291 command. The dials appear correctly in PanelDue (latest firmware) but with a 2mm based scale (20, 2, 0.02 etc.) in contrast with what appear at DWI that shows 10, 1 and 0.1mm buttons (much better). Also the movement DOES NOT WORK from PanelDue. It only works from DWI.
      The second issue is after the probe heigh is reported I send a command G31 Zn (with the new probe value) followed by a M500 to store it at the config-override.g. But this files does not change the overrride file in any way!!! How do I commit the new Z value to the config.g without doing it manually?
      Thank you!
        By default, M300 does not save the the trigger height to config-override.g. The only values saved to config-override.g by M500 are ones obtained by an automatic tuning process, e.g. heater turning or delta calibration. We made this change because too many users were having trouble when there was a G31 command in config-override.g. However, if you send M500 P31 then the G31 parameters will be written to config-override.g too.
        brunofporto 1 Reply Last reply Reply Quote 0
        • brunofporto
          @dc42 said in Macro for Calibrating Z Probe - Issues:
          M500 P31
          Thank you very much DC42.
          Please, is there a way to use the reported probe height from G30 S-1 to automatically crate a G31 Z"new value" within the macro?
          ps.: Have a nice vacation! 😄
          • brunofporto
            Also,
            Please, where is the correct place to report the M291 bug with PanelDue?
            It does not allow the user to adjust the head position on the specified axis from the screen.
              dc42 administrators @brunofporto last edited by
              @brunofporto said in Macro for Calibrating Z Probe - Issues:
              Also,
              Strange, it used to work. Did you home the specified axis first, or else use M564 H0 in config.g?
              • brunofporto
                brunofporto @dc42 last edited by
                M500 P31
                This command saves at the config-override.g these settings from the probe:
                ; Z probe parameters
                G31 T1 P600 X30.0 Y0.0 Z0.59
                G31 T3 P500 X0.0 Y0.0 Z0.70
                G31 T4 P500 X0.0 Y0.0 Z0.00
                At the Gcode description page it states that the Tnnn is for the probe type. My probe is a type 5. Is the "T1" parameter saved at the override correct?
                • brunofporto
                  I did home before, the M291 command is right after the G92 Z15, and it works fine at the DWI.
                  And I do not have the M564 command at my config.g.
                    M500 P31
                    Yes, probe types other than 3 and 4 share the same set of parameters as type 1.
                      I'll add this as an item to test/fix in the next release of PanelDueFirmware.
                      brunofporto 1 Reply Last reply Reply Quote 1
                      • brunofporto
                        Thank you very much! 😄
                        • brunofporto
                          For the record this is the working Macro and instructions:
                          ;======== Calibrate Z Probe Macro=========
                          ;Calibrate_Zprobe.g
                          G28 ; Home all axis
                          G92 Z15 ; DANGER!
                          M98 P/MACROS/SUBMACROS/BEEP.G
                          After the process send G31 Znnn where nnn is the reported probe Height
                          Send a M500 P31 to record the settings to config_override.g
                          Make sure you have M501 at your config.g to load the override settings.
                            I have also noticed this bug. I use a similar macro and in others that the axis movement buttons will only work from the place the macro was launched. So if you start the macro from the DWC the buttons will work there but not on panel due and vice versa.
                            Its also a little odd that the scale for movement values is different between the two.
                            Also perhaps this would be if interest to you.
                            https://www.dropbox.com/s/8okrxrgtx2d8om7/0_Auto Probe Trigger Height Assist.g?dl=1
                            brunofporto 2 Replies Last reply Reply Quote 0
                            • brunofporto
                              brunofporto @Phaedrux last edited by
                              @phaedrux said in Macro for Calibrating Z Probe - Issues:
                              I find that odd too.. I'll check your macro thank you!
                              I did not test launching the macro from the PanelDue. I'll try that 😄
                              • brunofporto
                                I am not able to use M109 anymore...
                                For starting gcodes I am using M116 H0 for the bed and then M116 to wait for the hotend too (tried to define the tool but P0 pr P1 did not work. As the bed was already at temp at this part then the the full m116 worked nicely to wait for the tool)
                                I liked the preheat for probing and also the grid compensating map - I think this is causing me issues with my current macro. I'll use your as reference! Thank you very much 😄
                                  If you're interested I also have a macro to assist in manual bed leveling and another to run mesh compensation. Amung others.
                                  https://www.dropbox.com/sh/j8qaxkkardoxzja/AADUDwfeBvVTpXzcr0nOpSPZa?dl=0
                                  • brunofporto
                                    Sure I am 😄
                                    Loved your probe macro! Made my macro looks like a kids drawing in comparison 😬
                                    Thank you very very much.
                                    • brunofporto
                                      DC42, only to confirm @Phaedrux mentined and add some details do the bug.
                                      If I start the Macro from the PanelDue I can only send the movement commands from there. And vice versa. Also the results from the G30 S-1 (for example) from the macro only shows at the PanelDue console. And vice versa if I start the macro from DWC.
                                      One detail is that @Phaedrux macro test G30 S-1 ten times. This is reported correctly when the macro is started from DWC but only six of them appear at the PanelDue console.
                                      Thanks!
