    Change print speed in gcode
    Firmware wishlist
    3.4k
    • peirofundefined
      peirof
      I know this question it's not of this forum, but... I post for you can help me...
      I have to print a piece, the first 80% there is not problem but in last 20% are curved, vaults....
      I can generate the gcode, and in the layer when start vaults, reduce print speed... Maybe later height?
      I think that Slic3r PE, can do this...
      What line I have to insert in gcode for change print speed?
      Thanks
      • T3P3Tonyundefined
        T3P3Tony administrators @peirof
        @peirof If you want ot reduce the speed simply for the top 20% of layers then you can add the M220 command (or the speed slider on DWC) to a lower %:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M220_Set_speed_factor_override_percentage
        I assume though that that is not exactly what you are trying to do. Am I right in thingking you want only bridges to be printed slower? In that case it really is a slicer's job as it knows what parts of the print refer to bridges and what do not. the firmware does not know if a line it is laying down in over a gap or over a previous line.
        It is probably different in all firmware, but there should be a setting for bridge speed. Cura has just introduced these settings apparently (but I have not tried them):
        https://community.ultimaker.com/topic/22195-introducing-the-experimental-bridging-settings/
        www.duet3d.com
        • fmaundefined
          fma
          The other day, I had this idea: what about using a specific move G-code for each type of extruding move? This way, all speeds/accel/... could be changed dynamically by the firmware, while extruding.
          Frédéric
            dc42 administrators @fma
            @fma said in Change print speed in gcode:
            I proposed this at https://reprap.org/forum/read.php?1,803621 but I didn't get much support.
            T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
            • T3P3Tonyundefined
              T3P3Tony administrators @dc42
              @dc42 said in Change print speed in gcode:
              Its another chicken and egg problem. The slicers would need to label G1 moves with the move type before the firmware could implement that...
              www.duet3d.com
              • fmaundefined
                fma
                I think it should be first implemented by the firmware, as it is possible to generate test g-code files with scripts, or to modify real g-code files with post-processors, to have something working.
                Frédéric
                • T3P3Tonyundefined
                  T3P3Tony administrators @fma
                  @fma fair enough. I have moved the topic to the firmware wishlist section.
                  @peirof in summary - it cant be done by the firmware right now. it can be done by some/most slicers.
                  www.duet3d.com
