    Heater Fault Troubleshooting
    3.5k
    • jgbowmanundefined
      jgbowman @mrehorstdmd
      @mrehorstdmd Thank you, although switching out the pt100s doesn't even temporarily fix the problem for me, so I'm sure i'm having another issue. Will definitely look into the E3D sensors though.
        dc42 administrators @jgbowman
        @jgbowman said in Heater Fault Troubleshooting:
        @dc42 It says movement before homing is not permitted.
        Then the M564 H0 command in config.g isn't working. Try retyping it.
        jgbowmanundefined 1 Reply Last reply Reply Quote 0
        • jgbowmanundefined
          jgbowman @dc42
          @dc42 I tried moving it around a bit, but to no effect. Even though I put 1.20 and later in the configuration settings, config.g still says 1.17-1.19. Could this have something to do with my issues?0_1530811118179_config g2.PNG
          • T3P3Tonyundefined
            T3P3Tony administrators @jgbowman
            @jgbowman the header at the top of config.g is just a comment written by the configurator.
            If you go into the gcode console screen and type M564 H0, send that and then type M564. What does it report?
            www.duet3d.com
            • jgbowmanundefined
              jgbowman @T3P3Tony
              @t3p3tony That got it working, thank you
              • T3P3Tonyundefined
                @jgbowman ok thats interesting. So it works is entered directly, but not in config.g? Maybe try a reboot with it in config.g and see if it continues to work after the reboot.
                www.duet3d.com
