    Release 2.01beta1 Machine control movements wrong
    • almstsoburundefined
      almstsobur
      Core XY setup, Release 2.01beta1, with partner web control package. If I hit +100 Y or X it goes diagonal in the wrong direction and does not seem to be 100mm either. Does not effect printing as long as you dont do any manual control since a reboot. Otherwise the "off" mnaual control buttons seem to throw everything esqew.
      -RP
        There is a newer beta of the DWC that has some fixes. Maybe give that a try.
        https://forum.duet3d.com/topic/5485/duet-web-control-wishlist-notes-and-priorities/17
        • Danalundefined
          Danal
          From the changelog for https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.21.2-b2.zip
          Bug fix: G1 S2 moves were incorrectly generated for jog movements on Delta and SCARA configurations
          I am currently on
          Firmware Version: 2.0(RTOS) (2018-06-05b3)
          WiFi Server Version: 1.21
          Web Interface Version: 1.21.2-b1
          And DO see the issue on a Delta.
          • Danalundefined
            Danal
            Upgrading to:
            Web Interface Version: 1.21.2-b2
            DID fix it, moves are now correct. Specifically, I DID upgrade the web interface, I DID NOT upgrade the firmware to Chris' branch.
              Phaedrux Moderator @Danal
              @danal I believe that Chris's branch is only necessary to be able to rename fans. But that's just my reading of his post.
              Danalundefined 1 Reply Last reply Reply Quote 0
              • Danalundefined
                Danal @Phaedrux
                @phaedrux said in Release 2.01beta1 Machine control movements wrong:
                Agreed.
                That's exactly why I "tested" the B3 B1 combo... and I think we both read his post correctly! 🙂
