Weird G32/G29 Error
  • My G32 and my G29 doesn`t work anymore. Homeall works fine and in the directions i had defined. But if i send an G32 to the Duet my Hotend crashes against the front left motor mount.
    I tried this with FW 1.21 and with FW2.0 Set up the config complete new today and define also Minimum Axis to X/Y 20/20 and tried to define the bed.g at X40 Y270 at first point even then it rushes against the motor mount.
    I don`t had a clue anymore what to do exept of throw my Core XY out of the window
    If the problem has only occurred since you upgraded from an old firmware version, check whether you have any deployprobe.g and retractprobe.g files in /sys that you didn't create yourself, and delete them.
  • No, i had the problem since yesterday and didnt use a BL-Touch. I had an Orion and before an IR Probe. Just updated today from 1.21 to 2.0 and made the config complete new but both changed nothing. There aren`t deployprobe.g or an retractprobe.g in my sys.
    So it was working correctly with firmware 1.21 before? If so then it looks like the changes to the config files caused the problem.
  • No the error started at FW 1.21 and i did an upgrade to exclude an FW error. also G30, Homez and homeall did work but G32 and G29 doesnt do whats in bed.g or in M557
    What did you do that triggered the error: a firmware upgrade from a version earlier than 1.21, or something else?
  • I run the FW 1.21 a couple of weeks, two weeks ago i changed from IR Probe to Orion. I first thought i made a mistake at my config.g yesterday, so i build a new one today. As this didn`t worked i made the FW Update to exclude an Firmware Issue.
    Then i thought something on the Board is broken but G30, homeall and homez worked as they should.
    Dont shure if this also is a part of the problem, but my last 3 Thermistor and Thermistor Cables made Heater Faults if the cable is moved in the wrong way...
  • Tried it again, Setup Firmware again, Homeall works like a charm. Start G32, first start point should is defined in bed.g as X40 Y40 but he tried to move to X-90 Y-90? What am i doing wrong?
    Do you have any deployprobe.g. or retractprobe.g files that shouldn't be there?
  • @dc42 No, even after the new Installation of the Firmware isn't there a deployprobe.g or an retractprobe.g
    Please share your config.g and bed.g files.
  • config.g
    ; generated by RepRapFirmware Configuration Tool on Sat Jun 30 2018 19:52:00 GMT+0200
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    M667 S1 ; Select CoreXY mode
    M550 PHEVO ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X80 Y80 Z800 E2673 ; Set steps per mm
    M566 X1000 Y1000 Z1000 E240 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z250 E40 ; Set maximum speeds (mm/min)
    M201 X800 Y800 Z250 E1000 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X280 Y280 Z250 S0 ; Set axis maxima
    M574 X1 Y1 S1 ; Set active high endstops
    M558 P8 I1 R0.4 Z1 F300 ; Set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X140 Y140 Z-0.1 ; Set Z probe trigger value, offset and trigger height
    M557 X20:280 Y20:280 S20 ; Define mesh grid
    M307 H1 A469.9 C164.2 D9.6 B0
    M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 F1 ; Define tool 0
    M106 P1 S0
    M572 D0 S0.08 ;Pressure Advance
    bed.g
    ; bed.g
    ; Probe the bed at 4 points
    G30 P0 X40 Y40 H0 Z-99999
    G30 P1 X40 Y140 H0 Z-99999
    G30 P2 X40 Y270 H0 Z-99999
    G30 P3 X140 Y270 H0 Z-99999
    G30 P4 X270 Y270 H0 Z-99999
    G30 P5 X270 Y140 H0 Z-99999
    G30 P6 X270 Y40 H0 Z-99999 S0
    In your G31 command you have specified that the Z probe is offset from the nozzle by 140mm (which is a very large offset) in both X and Y. So in order to put the probe at 40,40 the firmware has to put the nozzle at -100,-100.
  • facepalm feels like an idiot, doesn`t see that. Redefine the offset in G31 and everythings fine now. Thanks!
