    simple filament run out switch
    1027
    • sjason1377
      sjason1377 Banned last edited by
      I would like a simple filament runout roller switch connected to end stop to trigger pause.g but don't I read firmware only supports that printing from sd card. I have never done that and never will. I use web interface. Or does that count as sd card print?
      RudydG T3P3Tony 2 Replies Last reply Reply Quote 0
      • RudydG
        RudydG @sjason1377 last edited by
        @sjason1377 Yes, if you upload and print with the web interface, it works. I installed a simple microswitch, and printed 10 almost empty reels this weekend 😉
          When you upload through the web interface you are uploading the file to the onboard SD card. It means to say that it wouldn't work if printing over USB.
          sjason1377 1 Reply Last reply Reply Quote 1
          • T3P3Tony
            T3P3Tony administrators @sjason1377 last edited by
            @sjason1377 If the file is uploaded to the SDcard (normally via the web interface) then the Duet has control over it and so can pause/resume etc. To use a simple switch as a filament out sensor see:
            https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors#Section_Firmware_1_18_and_earlier
            • resam
              resam last edited by
              @T3P3Tony the wiki page you linked seems to be a bit outdated.
              M591 supports many more filament sensor types now! https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
              T3P3Tony 1 Reply Last reply Reply Quote 1
              • T3P3Tony
                T3P3Tony administrators @resam last edited by
                @resam the page did mention simple switches and pulse generating sensors. I have updated it to make it clearer by listing all the types on the page.
                • sjason1377
                  thanks for that, you are great at responses!
                  • sjason1377
                    sjason1377 Banned @Phaedrux last edited by
                    @phaedrux thanks for the clarity! plain simple understanding.
