    I get mad with the configuration of my capacitive Z-probe
    • Alpenprinterundefined
      Alpenprinter
      Hi!
      I get mad with the configuration of my capacitive Z-probe.
      The probe is connected to E0 switch. It switches the E0 led on the duetwifi as it should. P0 changes to P1000.
      On the web interface, in machine status, the Z stop does not change status, but the E0 status does when switching.
      And further more I can't invert the E0 status.
      What I am doing wrong? Could s.o. please give me a hint on this?
      M574 Z2 S0 ; Set active low endstops
      M574 E0 S1
      M574 X1 Y1 S1 ; Set active high endstops
      M558 P4 I1 Z2 H3 F200 T5000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds H5 F120 T6000
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S20 ; Define mesh grid
      • timcurtis67undefined
        timcurtis67
        Which firmware version are you running?
        • T3P3Tonyundefined
          T3P3Tony administrators @Alpenprinter
          @alpenprinter said in I get mad with the configuration of my capacitive Z-probe:
          M558
          The "Z2" line in your M558 command is obsolete for versions of firmware after 1.19
          M574 Z2 S0 is an Z endstop at the high end of the Z axis, active low. Do you have an endstop at the top of your Z axis?
          Is this switching the Z endstop at Z max?
          Finally your G31 command looks odd to me, I expect you will have the capacitive probe offset by X, Y or both, unless you are using the tip of the nozzle as a capacitive probe?
          www.duet3d.com
          • resamundefined
            resam
            Don't rely on DWC - we just had the same issue recently.
            Use M119 to check the endstop status instead.
            See https://forum.duet3d.com/topic/5873/switch-z-probe-not-inverting/31 and the rest of that thread as well!
              A Z probe is not the same as a Z endstop! If you want to Z home the printer using a Z probe, you need to use different commands in your homing files. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z.
