    Feedback needed - Help with Slicer file information
    • T3P3Tonyundefined
      T3P3Tony administrators
      I am looking for some help in confirming which slicers produce "good" file information that is displayed properly in DWC.
      For example:
      Cura 2.7 (at least) and later:
      www.duet3d.com
      • boldnutsundefined
        boldnuts
        S3D
        • Dougal1957undefined
          Dougal1957
          Kiss 1.6.3
          • deckingmanundefined
            deckingman
            Don't know how to get the boxes that others have posted - maybe it's because I'm on an older version of DWC but Slic3R 1.2.9. gives Size in KiB if less than 1 MiB or MiB, last modified date and time, object height in mm to 1 dp, layer height in the format 0.3/0.3, filament usage in mm to 1 dp, generated by Slic3r 1.2.9. Prusa version 1.31.5 does the same but gives the date and time as well as Slic3r version in the "generated by" field.
            • T3P3Tonyundefined
              T3P3Tony administrators @deckingman
              @deckingman thanks Ian. The box is on the Print Status page when a file is selected for printing. See the (newly revamped) DWC manual
              www.duet3d.com
                deckingman
                Ahh - this box......
                Edit. I was trying to do it without starting a print. No probs - just aborted it.
