    I am sorry! - D3D/RRF now working
    2.3k
    • mrehorstdmdundefined
      mrehorstdmd
      A couple things:
      At what speed/acceleration are these printed? A single 20 mm cube is too small to print by itself at reasonable speed/acceleration without a print cooler because the nozzle keeps putting down fresh plastic on still-hot plastic from the previous layer. Try printing two or three cubes, separated by a few cm in one go.
      Cura defaults to 2.85 mm filament diameter and will grossly under extrude if you don't change the setting in the custom printer set-up (machine settings, extruder tab). The same value also shows up as the default diameter in the material section, even if you select a "generic" material, and can't be changed unless you set up a custom material. When you set up custom material, be sure to check the bed and extruder temperatures.
      pro3dundefined 1 Reply Last reply Reply Quote 0
      • pro3dundefined
        pro3d @mrehorstdmd
        @mrehorstdmd
        Thanks for helping out - I am lost
        I am printing them exactly same settings as on the ramps - same filament everything. The extrusion is taken care of now as it was wrong at first in Cura 341 - but not my later samples
        I am running 2000/20 in acc/jerk and 50mms with 10s minimum layer time to ensure cooling between nozzle touch
        Why does the ramps controller handle it and not the duet? Let me try printing 2 cubes to see if it helps
        Here are some samples with different settings: I understand the XY not being all that great with no fan but the corners should be same as on ramps no?
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
        dragonnundefined 1 Reply Last reply Reply Quote 0
        • dragonnundefined
          dragonn @pro3d
          @pro3d do a temp tower. As said before the same temps from ramps and Duet can by different in real world.
          • pro3dundefined
            pro3d
            It does appear to be the temp yes. Printing two at the time did improve - these at 1/32 I0
            Now the corners are fine
            I have some retraction calibration to do - thanks again and sorry for being a pain in the world cup
            • pro3dundefined
              pro3d
              So here is the cube with a layer fan at 60mms
              It is very good so I just need to figure out what caused the skip. The bed is almost floating so might be that or due to motor skip. Not sure. I did tighten my belts
              Here is one at 50mms
