Whats wrong?
@peirof said in Whats wrong?:
Measure voltage with USB connected. NO?
With steppers of, i have to read aprox 3.3V
With steppers moving, i have to read 0.0VCorrect?
Those are the correct pins to check. With USB power only supplied, you should get 3.3V between them. When you apply VIN power, it should drop to 0V.
hi,
i have do....
1- With Usb only power..... V=1.72
2- If i power on..... V=2.92
3- If i power off.... Voltage drops slow until 1.72 -
Those figures are not right. I think we need to exchange your Duet and examine it to see what is wrong.
can you give me instructions?
If you bought it from Duet3d then please complete the form at https://docs.google.com/forms/d/e/1FAIpQLSdyf6gGP_ncZachWi2HH7qx1kc5TE9WeEbz83VFBckm1JBXbQ/viewform. Otherwise, contact whoever you bought it from.
Hi @peirof, I've just experienced a very similar fault on one of my bench test systems. So I suspect a firmware issue. I am investigating it now.
@dc42 said in Whats wrong?:
Hmm, I can't reproduce the problem since I reset the board. But i definitely had a similar issue: firmware thinking that everything was normal, but motors not turning.
