    WiFi reported error: no known networks found
    • JuL
      JuL last edited by JuL
      I received today my DuetWifi and i'm trying to connect wifi with no luck.
      I did exactly what's in the "getting connected" section. If I send M587, i can see my network is correct. Is there something i'm missing? is there a blinky led when I do M552 S1?
      firmware : 2.0(RTOS)
      EDIT: I have hidden SSID, but same when not
      EDIT 2 : finally, works when SSID not hidden, but tell me "wrong password", wich I'm sure is correct.
      EDIT 3 : seems to work with NOT hidden SSID and change wifi chanel from 10 to 4
        If the SSID is hidden then you need to specify the SSID you want to connect to in the M552 command. See the description of M552 in the GCode wiki page.
        • JuL
          JuL last edited by
          thanks for your answer.
          I tried with no luck, my board definitely doesn't want to work on an hidden ssid.
          And for an unknow reason, my password doesn't work on wifi chanel 10 but work like a charme on N°4
            Are you running version 1.21 of the WiFi firmware? Some older firmware versions didn't support connecting to hidden SSIDs.
            • JuL
              I think so. I'll try to flash it to be sure
              EDIT : It doesn't work šŸ˜ž (no blinking led on the wifi module at start when hidden)
              As you can see, my board know well my network
              • T3P3Tony
                T3P3Tony administrators @JuL last edited by
                @jul When you connect to the hidden network, you need to include it in the M552 command:
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
                M552 S1 P"MyNetwork"
                Duet Hardware Designer
                www.duet3d.com
                • JuL
                  @T3P3Tony You rock !
                  @dc42 You rock to šŸ™‚ (I didn't read well your answer)
                  Thanks
