    First Layer
    811
    • Puppet172
      Puppet172 last edited by
      I am using a z probe mesh bed level and home the z and i keep having to change the trigger height every couple prints to get that good first layer because if i don't either its way to high or scraping the bed. Is this normal or should i be changing something else?
        What firmware version are you using?
        brunofporto 1 Reply Last reply Reply Quote 0
        • Puppet172
          @Phaedrux
          Firmware Electronics: Duet WiFi 1.02 or later + DueX5
          Firmware Version: 1.21 (2018-03-21)
          WiFi Server Version: 1.21RC4(08b3)
          Web Interface Version: 1.21.2-b1
          Web Interface by Christian Hammacher
          Licensed under the terms of the GPL v3
          • brunofporto
            brunofporto @Phaedrux last edited by
            @phaedrux said in First Layer:
            Another case of using G1 instead of G30, like me, at the homez.g or homeall.g?
              Can you post your config.g and homing files?
              What type of probe are you using? Type of printer?
              • Puppet172
                Puppet172 last edited by Puppet172
                @Phaedrux @brunofporto
                4_1532704494366_homez (2).g 3_1532704494366_homey.g 2_1532704494366_homex.g 1_1532704494366_homeall (1).g 0_1532704494366_config (4).g
                https://www.amazon.com/gp/product/B00S50O152/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
                my printer i built myself and its a cartestian i believe and it has a massive build area of ~3ft cubed
                  Your trigger height for your probe is negative in the G31 command. Meaning it triggers 2.3mm below the bed surface. How did you measure the trigger height?
                  Puppet172 1 Reply Last reply Reply Quote 0
                  • Puppet172
                    Puppet172 @Phaedrux last edited by
                    @phaedrux
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                      I think you should give firmware 2.01 a go to see if one of the recent bug fixes for mesh leveling solves your issue.
                      When you do, clear your Heights map, rerun the trigger height measuring, and redo g29. Then make sure your new height map is being loaded before a print with g29 s1.
