    inconsistent behavior - duet wifi on latest beta
    1761
    • Mentaluproar
      Mentaluproar last edited by Mentaluproar
      I'm running beta 2.0(RTOS) (2018-06-05b3). This board is being move from a machine I'm decommissioning onto my delta.
      I'm having some config trouble. In troubleshooting it, I've found the board behaves strangely. Sometimes, config.g is deleted from the card for no reason. When this happens, any undelete tool can bring it back undamaged. Usually, config.g.bak survives, but it doesn't contain anything recent. Sometimes, tool fan and fan 2 are linked, and sometimes they are treated as separate fans. Sometimes, the delta homing flys off the plate and into a pillar, sometimes it probes normally.
      Here's a video showing some of the behaviors.
      https://youtu.be/SzCLU_PVHoU
      Edit: here are my configs....
      config.g
      ; generated by RepRapFirmware Configuration Tool on Wed Jul 25 2018 20:40:36 GMT-0400 (EDT)
      M555 P0 ; Set firmware compatibility to look like native output
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R134 L217 B115 H292 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PRanKossel ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z80 E3000 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X600000 Y600000 Z600000 E600000 ; Set maximum speeds (mm/min)
      M201 X1500 Y1500 Z1500 E1500 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P4 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P600 X0 Y0 Z14.7 ; Set Z probe trigger value, offset and trigger height
      M557 R115 S20 ; Define mesh grid
      M143 H1 S260 ; Set temperature limit for heater 1 to 260C
      M106 P2 S1 I0 F500 ; Set fan 2 value, PWM signal inversion and frequency.
      M563 P0 D0 H1 F2 ; Define tool 0
      bed.g
      ; bed.g
      ; called to perform automatic delta calibration via G32
      G28 ; home all towers
      ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y114.9 H0 Z-99999
      G30 P1 X99.51 Y-57.45 H0 Z-99999
      G30 P2 X-99.51 Y-57.45 H0 Z-99999
      G30 P3 X0 Y0 H0 Z-99999 S3
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      homedelta.g
      ; homedelta.g
      G91 ; relative positioning
      G1 S1 X999 Y999 Z999 F6000 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
        I would suggest doing a full backup and format of the SD card just to make sure it's working properly.
        The SD card association has a formatter that will format it properly for the card type.
        https://www.sdcard.org/downloads/formatter_4/
        Do you have a spare card you can test?
        • Mentaluproar
          Before I transferred the board I did wipe the card with the SD formatter tool and completely redid it. It used to erase itself on my old machine too but once I got the config where I liked it and left it alone, it stopped happening, so I thought it was a firmware bug.
          Danal 1 Reply Last reply Reply Quote 0
            Can you grab a M122 diagnostic the next time it happens? Might shed some light.
            • Danal
              Danal @Mentaluproar last edited by
              @mentaluproar said in inconsistent behavior - duet wifi on latest beta:
              After you rebuilt the card and put it in a Duet... did you issue the M commands to update firmware in both the Duet and the WiFi module? Or equivalent?
              Shot in the dark here... but I'm wondering if there is somehow an incompatibility between what is running in flash on the controllers vs. something on the card. Maybe.
              • Mentaluproar
                No. I thought the firmware did little more than load what was in the card to memory. What are those M codes?
                • Danal
                  Danal last edited by Danal
                  M997 S0:1U date firmware modules 0 and 1. This should be what you want for a Duet Wifi
                  S0 - main firmware
                  • Older releases filename was sys/RepRapFirmware.bin (Duet) or sys/DuetWiFiFirmware (Duet WiFi).
                  • Latest releases, filename is /sys/Duet2CombinedFirmware.bin
                  • File sys/iap.bin (Duet) or sys/iap4e.bin (Duet WiFi) must also be present.
                  1 - web server firmware
                  • Filename sys/DuetWiFiServer.bin (Duet WiFi only)
                  Latest released binary files Here: https://github.com/dc42/RepRapFirmware/releases I do recommend the very latest releases, I'm running them on a couple of different Detlas, no issues.
                  AFTER you do those upgrades, you may also want to refresh DWC (Duet Web Control), just to be sure. Upload the whole zip file (don't unzip) through the Settings>General>Upload web stuff. https://github.com/chrishamm/DuetWebControl/releases
                  • Mentaluproar
                    @danal said in inconsistent behavior - duet wifi on latest beta:
                    M997 S0:1
                    Error: M997: File DuetWiFiServer.bin not found
                    interesting....
                    • Mentaluproar
                      reinstalled firmware. probing still crashes into tower. config.g has not disappeared yet so far.
                        I assume you mean probing, not homing. If you have old deployprobe.g and retractprobe.g files in /sys on the SD card, delete them.
                        • Mentaluproar
                          no probing files. I must have configured something wrong. delta tries to probe larger than the bed.
                          • Mentaluproar
                            I'm dumb. I made a typo in the M665 line.
                            • Mentaluproar
                              config.g disappeared again. Twice. I can undelete it every time without a problem. Given how FAT32 works, I'm thinking something in the firmware is telling it to delete the file.
                                dc42 administrators @Mentaluproar last edited by dc42
                                Which firmware and DWC versions are you using?
                                I don't think the current firmware and DWC versions ever delete config.g. When you edit it in DWC and save it, I think it first deletes config.bak if it exists, then renames config.g to config.bak, then uploads the new config.g. Or chrishamm may have implemented it another way, such as uploading to config.new first and then doing a double rename. Either way, if the process fails you should still have the old config.g renamed to config.bak.
                                • Mentaluproar
                                  config.bak is generally there. I think it has vanished before too but I can't remember.
                                  • kungfueinstein
                                    kungfueinstein last edited by
                                    its just disappeared for me too. this is not the first time. Also having problems opening the DMS file to restore the bak.
                                    dc42 1 Reply Last reply Reply Quote 1
                                      dc42 administrators @kungfueinstein last edited by
                                      @kungfueinstein said in inconsistent behavior - duet wifi on latest beta:
                                      When it disappeared, were you editing it and trying to save it? Or was it after you uploaded a new file to /gcodes?
                                      How many files do you have in the /sys folder? There is a limit to how many files in a folder the firmware can return to DWC. Although this normally affects only the /gcodes folder, it could affect /sys if you have a lot of files in it.
                                      • Mentaluproar
                                        I've only had the files necessary for operation in the sys folder. I only ever notice config.g isn't there when I go to edit it. Sometimes I'll realize I forgot to do something after it goes to reboot the board, so I'll wait, then go back to system editor and see the file is gone.
                                        I don't know if this is relevant, but if I reload the page (like if it's on a tab and my mac has to reload the tab because I was doing lots of other things) the board will repeat the last few instructions sent to it. Even if it is printing, it will interrupt the print to home and calibrate. This happens every time on safari, and a little less frequently on firefox.
                                        Basically, once it's all dialed in, the board works great, but interacting with it in any way leads to unpredictable results. Still nowhere near as bad as octoprint though.
