    Bed Leveling on a Cartesian printer
    bed leveling
    1106
    • fcwilt
      fcwilt last edited by fcwilt
      In reading the documentation on manual bed leveling it states that I need 3 or 4 adjusting screws.
      My printer (an FT-5 with all of the 713 add-ons) has 8 adjusting screws - 4 at the corners, 2 in the middle of the sides parallel to the Y-axis and 2 near the middle of the sides parallel to the X-axis (I have no idea why they are not in the middle).
      Anyway so what do I do?
      I could chose two corners and one in the middle of the opposite side.
      I could chose the four corners
      Or do I use all eight despite what the documentation states?
      Thanks.
      Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
      • mrehorstdmd
        mrehorstdmd last edited by
        Wow! They're sort of taking "more is better" to a whole new level. How does FolgerTech recommend you adjust all those?
          The maximum number of adjusting screws supported is currently 4. I can increase it to 8 in the next build if that would be useful.
          If there are 8 adjusting screws on the bed, that suggests to me that it must be quite flexible.
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt @dc42 last edited by fcwilt
            @dc42 Thanks for the feedback.
            This is my first non-delta printer and I am still learning.
            The plate is supported by springs on each of the 8 adjustment screws.
            So perhaps there are 8 to insure good support?
            For leveling I thought that 3 made the most sense since 3 points define a plane but perhaps that would not provide enough support?
            The 4 corners make sense when it comes to providing decent support while still being easy to adjust the plate to level.
            The additional ones I don't fully understand. The plate is one of the 713 pieces and is 6mm aluminum. It will flex if you adjust the middle screws. Perhaps the plates aren't completely flat to begin with?
            And why two of the "middle" ones aren't in the exact middle is also beyond me.
            Like I said this is a new type of printer for me and I have much to learn.
            Thanks.
            wilriker 1 Reply Last reply Reply Quote 0
              If it's 6mm plate could you just remove 5 of those 8 screws and use the remaining 3 to level it properly?
              It might be worth it to check some of the Folgertech user groups and see what other users are doing.
              If you still wished to use all those screws for better bed support and didn't want to wait for official automatic bed leveling support you could use a macro to move the nozzle around to the various points, and then adjust the screw until the bed touches the nozzle. With 8 points though it would probably take a few passes over each to get them into agreement.
              0_1533101620947_0_Auto Bed Level Assist.g
              Here's what I currently use for just 3 points, but you could easily modify it for your purposes by duplicating the positioning sections with your own screw coordinates.
              • fcwilt
                fcwilt @Phaedrux last edited by
                @phaedrux said in Bed Leveling on a Cartesian printer:
                Thanks for the feedback. That is quite the g file you have devised there. I have never contemplated anything quite so comprehensive.
                I did create 8 macros to move from adjustment point to adjustment point and used them to adjust the screws manually. It took a few passes but it came out rather well.
                I now want to print a simple test cube to see how things are working.
                I also want to investigate fitting some sort of Z-probe.
                Thanks again.
                  Yeah it seems a little crazy to see it at first but it really makes re leveling a snap. I have another one I run after that to measure the probe trigger height and then another to run mesh grid compensation mapping. Just follow the prompts on the screen and it does everything exactly the same every time.
                  • WalterSKW
                    WalterSKW last edited by
                    I do have an older FT5. I use only the 4 leveling screws on the edges.
                    I still have the 4mm original ALU-bed and it's fine to me.
                    I suppose the 713 machined bed is at least 6 or 8mm thick and should have no issue at all.
                    Hope this helps.
                    Brian once said: "Always look at the bright side of life"
                    Works for me!
                    • fcwilt
                      I contacted 713 and they suggested just using three of the adjustment screws, two in the corners and one in the middle of the opposite side.
                      So I'm going to try that and see how it goes.
                      • wilriker
                        wilriker Moderator last edited by
                        @fcwilt It took me a while to realize that "713" is some kind of brand name and not the total count of upgrades for this printer and you installed all of them. 😂
                        Manuel
                        My Tool Collection
                        Phaedrux fcwilt 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @wilriker last edited by
                          @wilriker Same here.
                          https://713maker.com/
                          Then I realized I'd seen them before for their RailCoreII kits.
                          • fcwilt
                            fcwilt @wilriker last edited by
                            @wilriker said in Bed Leveling on a Cartesian printer:
                            My bad for not being clear.
                            713 is not a common name but I thought it was well known in the FT-5 world.
                            • wilriker
                              wilriker Moderator @fcwilt last edited by
                              @fcwilt No reason to apologize... It was a fun moment when I finally realized it. 😂
                              Manuel
                              My Tool Collection
                              • wilriker
                                @fcwilt said in Bed Leveling on a Cartesian printer:
                                In thought about that part of why two of the holes are not in the middle of an edge. It might be that is to realize a mounting style quite similar as @mrehorstdmd does (described in his blog). The only reason why this would be offset from the middle compared to Mark's solution is probably because the bed of a Cartesian is moving back and forth (compared to just up and down) and to reduce the pivoting around these two points by simply offsetting it from the center of mass (not sure if this sentence is fully understandable).
                                Manuel
                                My Tool Collection
                                • fcwilt
                                  @wilriker
                                  When I asked about the placement of the holes 713 replied that they matched the original part made by Folger Tech.
                                  But since 713 said to use just three adjustment screws it is a non-issue.
                                  I made some very simple test prints and even without any tweaking of settings and such they are better than what I have been able to get out of my deltas. Not a whole lot better but noticeable.
