    Laser Filament Monitor - Testing
    Filament Monitor
    11
    21
    1994
    • T3P3Tony
      Thanks to those who have offered to test the filament monitor. I have contact many of you and your filament monitors should be arriving around now.
      I have updated the documentation with some more images and some thoughts on areas for experimentation:
      https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion#Section_Experimentation
      Included is a link to the youmagine page hosting my modified housing OpenSCAD that has some more options for experimentation.
      It will also be helpful to get feedback on specific filament types and successes with those. To that end can I as that experimentation is split into two categories:
      1. Filament testing - for this use please use the standard housing that DC42 linked form the thingiverse project
      2. Housing experimentation and other experimentation - for this it would be good to use a filament you have tested using the standard housing already.
      I still have some more laser monitors if anyone else would like to get involved.
      Duet Hardware Designer
      www.duet3d.com
      • PcS
        PcS last edited by
        I would be interested in testing as well.
        • DK90
          DK90 last edited by
          I am also interested in testing the Filament Monitor
          • fma
            fma last edited by fma
            I'm also interested to test it, with folks of the hackerspace, here in Grenoble (France)...
            Frédéric
            • tkamsker
              tkamsker last edited by
              Hi DC42 i would also be interested , I have 2 Duet3d one for a Bigbox in idex and one on an 300x300 Corexy Hevo Style Printer with an Dual E3d Chimera head on it.
              (I also have 2 I3 type printers not on Duet where we could test 3mm if needed)
              I can add oscilloscope and development skills if needed to get that going
              thx thomas
              • insertnamehere
                insertnamehere last edited by
                Hi DC42,
                If you have a spare laser filament monitor, I'm happy to test for you.
                I use mainly eSun PLA and PET-G filament and Hatchbox Wood.
                I have about 15 different colours right now.
                • pkos
                  pkos last edited by
                  Same here. Modded Ender3 now with duet wifi and titan aero 1.75, using a variety of filaments.
                  Waiting for parts and then will build a HEVO with the duet. The filament sensor would be amazing for it 😉
                  Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron 0 (Duet 3 mini 5+ standalone)
                    We have a pre-production batch almost ready to ship. More news soon.
                    • DocTrucker
                      DocTrucker last edited by
                      I knew there was something else I wanted to ask you guys about at TCT! Having lost my big 24V core xy system through redundancy I'm down to my v0.6 (x3!) and 12V.
                      Are the current revisions likely to play well with the Maestro boards along with the Duet 2?
                      Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
                      • T3P3Tony
                        T3P3Tony administrators @DocTrucker last edited by
                        @doctrucker the filament monitors will.work on the Maestro, Duet 2 and we plan for forward compatability to future versions of Duet.
                        www.duet3d.com
                        • DocTrucker
                          Thinking about this a little further could I hook the development sensors to a spare arduino due and just read distances from it? With a bit of coding? Is the rotating magnet version mentioned on the documentation likely to be more reliabke than the laser based or are these questions for the trials to answer?
                          • T3P3Tony
                            @doctrucker yes you can
                            Rotating magnet is very accurate across all filament types.
                            www.duet3d.com
                            • DocTrucker
                              Very interested in trying it from that perspective then. It'll be far superior to me measuring filament by eye with a 150mm metal rule! Where can I express an interest in buying a beta model of the magnet based sensor - or is it not ling to wait for the planned commercial release? I realise the date may slip due to beta trial results.
                              • 3dmntbighker
                                3dmntbighker last edited by 3dmntbighker
                                I have been using my laser sensor now for a short while. With black PLA I had mostly consistent results. I started using eSun yellow PETG and made several small prints with the same travel numbers. Last night I started a vase mode part and it got to about layer 160 before it stopped. The reported low number was 24%. I restarted the print and it went another 10 layers and stopped again. The restart was perfect, but the layer adhesion was non-existent. It printed another 10 or 15 layers and stopped again with 24%. The average range up to this part printing was 84% to 94%. When I checked the vase as the print was getting started it was also 85 to 95%. I'm not sure what is going on. The filament feed is not restricted and I'm using a Bondtech extruder. The quality of the print was as near perfect as I could ask for, and I'm using a fairly high temp so the nozzle is very unlikely to be getting clogged. I had the print speed at 40mm/s.
                                Ideas? Does retraction mess with the sensor? In vase mode there should be no retraction.
                                I have yet to install the laser sensor in my second printer, but it's ready to go.
                                Scratch built CoreXY with Maestro
                                Heavily modified Ender 3 with Maestro
                                MPCNC work in progress with Duet WiFi
                                • T3P3Tony
                                  T3P3Tony administrators @3dmntbighker last edited by
                                  @3dmntbighker the sensor performs differently depending on the filament types as you have seen. For PETG we have reports that ESUN Black was very poorly registered which I have confirmed on tests. I have not confirmed for ESUN yellow PETG however it looks like that is also not good. If you are getting +'ve numbers you can increase the trigger window for that filament.
                                  www.duet3d.com
                                  3dmntbighker 1 Reply Last reply Reply Quote 0
                                  • 3dmntbighker
                                    3dmntbighker @T3P3Tony last edited by
                                    @t3p3tony said in Laser Filament Monitor - Testing:
                                    Very odd that it goes from 85 to 95%, then suddenly out of nowhere it's 24% with no change in speed, feed rate or filament type.
                                    • T3P3Tony
                                      @3dmntbighker yes that is strange. I found the ESUN black PETG very variable with unworkable results, however other PETGs (specifically e3d edge) are not as variable.
                                      www.duet3d.com
                                      • 3dmntbighker
                                        Well, I have stopped buying eSun altogether. My standard filament brand is now 3D Solutech. I also use a mix of Taulman, Filamentum and others. I hope they get Prusament on Amazon soon.
                                        • T3P3Tony
                                          @3dmntbighker will be very interested to hear how you get on with those other brands!
                                          www.duet3d.com
                                          • peirof
                                            peirof last edited by
                                            Hi...
                                            When you estimate filament monitor will be reléased? And the Price?
                                            Thanks
                                            DocTrucker 1 Reply Last reply Reply Quote 0
                                            • DocTrucker
                                              DocTrucker @peirof last edited by
                                              @peirof https://www.duet3d.com/DuetAddons/LaserFilamentMonitor
