    Phaedrux Cannot move x-y-z axis on my cr-10 help!
    608
    • ngwpower
      ngwpower last edited by
      Cannot move my xyz axis on my cr-10 with
      Firmware Version: 2.01beta2(RTOS) (2018-07-14b5)
      WiFi Server Version: 1.19
      Web Interface Version: 1.21.1
      Please help
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool on Sun Aug 05 2018 11:24:11 GMT-0700 (Pacific Daylight Time)
      G91 ; relative positioning
      G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X5 Y5 F6000 ; go back a few mm
      G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 S1 Z-405 F1800 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z20 ; set Z to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
        I think you have some mismatched firmware versions
        Please update the following:
        https://github.com/dc42/RepRapFirmware/releases/download/2.01/Duet2CombinedFirmware.bin
        https://github.com/dc42/RepRapFirmware/releases/download/2.01/DuetWebControl-1.21.2-dc42.zip
        https://github.com/dc42/RepRapFirmware/releases/download/2.01/DuetWiFiServer-1.21.bin
        See if that helps.
        • ngwpower
          Alot just can't wrap my head around the 0 &1 for movement direction will get her done! Thank You. PS found the reputation button! DUH
            @ngwpower said in Phaedrux Cannot move x-y-z axis on my cr-10 help!:
            I'm not sure what you mean.
            ngwpower 2 Replies Last reply Reply Quote 0
            • ngwpower
              ngwpower @Phaedrux last edited by
              @phaedrux Hard time remembering which way the G Code sets the movement of the steppers 0 or 1. Just hard for my brain.will be okay after I get it sorted out. I am using a spreadsheet to follow my movements in Duet system editor. only way I can keep track of all this G Coding!.
              • ngwpower
                @phaedrux Getting the error, suggestions Please.0_1533839976775_error m997.jpg
                  Upload this one
                  https://github.com/dc42/RepRapFirmware/releases/download/2.0/iap4e.bin
                    Download iap4e.bin from the most recent release at https://github.com/dc42/RepRapFirmware/releases that includes it (release 2.0), and upload it through the Settings/General tab of Duet web Control.
                    Edit: Phaedrux beat me to it.
                    • ngwpower
                      Thank You both the Phaedrux file worked this time. You guys rock👍 😙
                      • ngwpower
                        This post is deleted!
