    Precision Piezo v1.2
    Third-party add-ons
    4.0k
    • Moriquendiundefined
      Moriquendi
      I found that the easiest way to check whether the bed was bowed or flexing about the leadscrews was to remove the plate and rotate it 90 degrees. If your readings now show a bow in the other direction then the bed itself is bowed, if the bow still appears to be in the same direction then the bed itself is moving.
      Idris
      3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
      • hevilpundefined
        hevilp
        @Moriquendi
        how does the "new" solution look like?
        Moriquendiundefined 1 Reply Last reply Reply Quote 0
        • 3dmntbighkerundefined
          3dmntbighker @Moriquendi
          @moriquendi The next thing I plan to do is remove my PEI sheet. This will be a massive pain getting all the 3M adhesive off. Then run a probe on the bare aluminum. I'm going to try using my new PEI sheet with clips but I'm afraid I won't get the heat transfer I want. Ultimately I want a removable spring steel "Prusa-esk" sheet with PEI coating. Or at least some for of removable springy build sheet.
          Scratch built CoreXY with Maestro
          Heavily modified Ender 3 with Maestro
          MPCNC work in progress with Duet WiFi
          • T3P3Tonyundefined
            T3P3Tony administrators @3dmntbighker
            @3dmntbighker if you want to try probing bate alu without removing the sheet can you turn the bed over as a test?
            www.duet3d.com
              3dmntbighker
              I can't rotate or flip over. I have a heater stuck to the bottom with the wires on one end. I got the PEI off last night and used about half a bottle of 91% Isopropyl so far trying to get the glue off. When I went to re-probe I found that the cheap Chinese wire I used for the Piezo probe has a break somewhere. So the nozzle crashed into the bed. Until I can get some decent wire and rebuild my gantry cable I'm dead in the water.
                Moriquendi @hevilp
                @hevilp It's like the Orion but instead of having the filament pass through the PCB it's designed to mount between two parts ( eg the extruder and the carriage), similar in concept to your carriage but more integrated.
                Idris
                  3dmntbighker
                  Here is the bare aluminum plate probe run. And BTW, I never put the M375 in config.g until yesterday. Doe!!!!!
                    3dmntbighker
                    Here is my latest probe run after thoroughly cleaning the glue off of the plate and doing 2 probes per point with bed at 70c and hot end at 180. I also increased the trigger threshold to 600 so it hits slightly harder. And it now has a stiffer Piezo upper mount I printed in Taulman 910. My BuildTak magnet system will be here tomorrow. I ordered an extra steel plate so I can have a Buildtak and a PEI option. At this point I won't be attempting to make the plate any flatter than it is.
                    edit:
                    I did a calibration print for square, and it appears I'm good other than a fraction of a degree off 90 degrees Z to Y. So my Z uprights are not quite vertical.
