    Setting large Z-Probe Offset
    • Carbonoidundefined
      Carbonoid
      My Z Probe is 53 mm below the nozzle tip.
      When I do the delta calibration the only way to prevent the probe from crashing into the bed is setting in M558 the H parameter to 53 (although I'd expect the head to stop as soon the probe is triggered). H < 53 crashes. So I have in config.g:
      M558 P4 I1 H53 F120 T3600
      G31 P500 X0 Y0 Z5
      Auto calibration works fine with H53 and the probe rises nicely to about 5mm above the bed between trigger points.
      What sucks is that after calibration the mesh bed leveling will always start very high > 53mm and probing would take forever.
      Also when I do a M500 after calibration the H value in M665 is way off.
      Any idea how to work with my probe setup on Duet?
      • T3P3Tonyundefined
        T3P3Tony administrators
        I think you should have your Z trigger height at 53 (or rather at exactly the distance between the nozzle and the height that the Z probe registers a trigger:
        G31 P500 X0 Y0 Z53
        That will allow you to use a more sensible dive height in M558
        Have a look here to see how to set the Z trigger height:
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Measuring_the_trigger_height
        www.duet3d.com
          Carbonoid
          @T3P3Tony thank you very much, that solved my problem!
