    X and Y motors not moving
    motor not running
    1579
    • samlogan87
      samlogan87 last edited by samlogan87
      Hi there everyone,
      I am having issues with the core xy printer that I am building. I am running 3x Z axis Nema 23 motors that are working fine, but the X and Y axis are not. I have tried switching the motors to the Z drivers and they work. Z axis ones do not work on drivers 0 and 1. I have a DueX2 and have put the x and y motors on there and it still does not work. I am thinking it could be something to do with the config. Can someone cast their eye over it and see if they can see anything.
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M667 S1 ; Select CoreXY mode
      ;M912 P0 S# CPU Temp
      M550 PSam's Printer ; Set machine name
      M552 P192.168.1.40 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes forwards X Axis
      M569 P1 S0 ; Drive 1 goes forwards Y Axis
      M569 P2 S0 ; Drive 2 goes forwards Z Axis 1
      M569 P3 S1 ; Drive 3 goes forwards Z Axis 2
      M569 P4 S0 ; Drive 4 goes forwards Z Axis 3
      M569 P5 S1 ; Drive 5 goes forwards Extruder
      ; Motor remapping for dual Z
      M584 X0 Y1 Z2:3:4 U3 V4 E5 P6 ; Driver 0 For X, 1 for Y, Z=2:3:4 U3 V4, Extruder 5
      M350 X16 Y16 Z16:16:16 U16 V16 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z400:400:400 U400 V400 E420 ; Set steps per mm
      M566 X150 Y150 Z12:12:12 U12 V12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X150 Y150 Z180:180:180 U180 V180 E1200 ; Set maximum speeds (mm/min)
      M201 X250 Y250 Z250:250:250 U250 V250 E250 ; Set accelerations (mm/s^2)
      M906 X850 Y850 Z1850:1850:1850 U1850 V1850 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 U0 V0 S1 ; Set axis minima
      M208 X400 Y400 Z420 U420 V420 S0 ; Set axis maxima
      M671 X256.6:-53.6:100 Y239.10:239.1:65.50 S3 ; Define the X and Y coordinates of the leadscrews. Motor order: FR (1), FL (2), RC (3).Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
      M574 X1 Y1 S1 ; X home to min. Y home to max. Normally Closed limit switches.
      M307 H5 A-1 C-1 D-1 ; Disable the 4th Heater to free up PWM channel 2 on the Duex board for BL TOUCH.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M558 P5 X0 Y0 Z1 H5 F120 T6000 ; MUST CHANGE H=== TO SUIT BEFORE RUNNING!!!!!!!!!!!!!!
      G31 X0 Y0 Z1.5 P25 ; MUST CHANGE X AND Y OFFSET BEFORE RUNNING AND THEN TUNE Z!!!!!!!!!!!!11
      M581 E0 S1 T1 C0 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input
      ; Define mesh grid
      M557 X0:400 Y0:400 S20
      M140 H1 ; Remap heated bed to heater 1
      M305 P0 X200 ; Set PT100 for Hot End
      M143 H0 S300 ; Set temperature limit for heater 0 to 300C
      M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 0 and use PID mode
      M305 P1 X201 ; Set PT100 Channel 2 to Heat Bed
      M143 H1 S130 ; Set temperature limit for heater 1 to 130C
      M307 H0 A249.7 C1079.9 D20.0 S1.00 V24.3 B0 ; set model parameters for heater 1 and use PID mode gain 249.7, time constant 1079.9, dead time 20.0,
      M106 P1 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H0 S"Extruder" ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"
      M913 X0 Y0
      G91
      M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      Regards,
      Sam
      Custom Core-XY
        If you send M584 with no parameters in the console what do you get back?
        • samlogan87
          Hi there,
          This is what I get:
          11:51:28 AM M584
          Driver assignments: X0 Y1 Z2:3:4 U3 V4 E5, 5 axes visible
          Regards,
          Sam
          Custom Core-XY
            Can you test without your additional axis defined?
            • samlogan87
              Yeah just tried it and nothing.
              Custom Core-XY
              • samlogan87
                this is what I have in there
                M584 X3 Y4 Z2 P3 ; Driver 0 For X, 1 for Y, Z=2:3:4 U3 V4, Extruder 5 :0:1 U3 V4 E5
                M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation :16:16 U16 V16
                M92 X80 Y80 Z400 E420 ; Set steps per mm :400:400 U400 V400
                M566 X150 Y150 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) :12:12 U12 V12
                M203 X150 Y150 Z180 E1200 ; Set maximum speeds (mm/min) :180:180 U180 V180
                M201 X250 Y250 Z250 E250 ; Set accelerations (mm/s^2) :250:250 U250 V250
                M906 X850 Y850 Z1850 E800 I50 ; Set motor currents (mA) and motor idle factor in per cent :1850:1850 U1850 V1850
                Does it look correct?
                Custom Core-XY
                • samlogan87
                  I have done some more troubleshooting. When I remap the extruder to one of the x and y drivers it works as it should. I can use the extrude and retract buttons to make the x and y axis to move. When I remap it back, I can not get it to home. The Z axis moves as it should, but the x or y won't move
                  Custom Core-XY
                    How are you trying to move the motors?
                    If you send this does the motor move?
                    G91
                    G1 S2 X10 F3000
                    • samlogan87
                      Currently I have just been trying to get it to home the axis. I have the homing g code files from the configurator and when I run it, the Z axis shifts up (down in my case being a corexy) and then nothing for the x and y until I push the end stops in. Once I do this, the z axis then moves again. It says that the axis have homed and when I try and shift it, nothing happens.
                      I will give that a try and let you know.
                      Custom Core-XY
                      • samlogan87
                        I gave that a go and it doesn't move.
                        Custom Core-XY
                          dc42 administrators @samlogan87 last edited by dc42
                          @samlogan87 said in X and Y motors not moving:
                          1. Please clarify: do you have X and Y mapped to drivers 3 and 4 as here, or mapped to drivers 0 and 1 as in the config.g file you listed in your first post?
                          2. You can send following commands to test the X motor individually:
                          G91 ; relative movement
                          G1 S2 X10 F1000 ; move the X motor forward 10mm
                          G1 S2 X-10 F1000 ; move the X motor back 10mm
                          Similarly for the Y motor.
                          • samlogan87
                            @dc42 said in X and Y motors not moving:
                            G1 S2 X-10 F1000
                            Hi there,
                            Yes sorry it is as the above configuration. I was just making sure in that bit, that it was not a motor issue by mapping it to other drivers. Turns out the motors are fine.
                            I tried that and nothing. They do not move at all.
                            I am very confused as they turn when I set them up as extruders and use the retract button on the UI
                            Custom Core-XY
                              Just on a lark, can you delete the entire line and type it out again from scratch?
                              • samlogan87
                                Yeap I did that.
                                G1 S2 X100 F1000 and it did not move at all
                                Custom Core-XY
                                  Sorry, I meant the M584 command
                                    Also, are you sure the x and y steps per mm are 80?
                                    You said when you switched them to be extruders they worked but the extruder steps are 400.
                                    • samlogan87
                                      Sorry I typed M584 and got
                                      M584
                                      I tried changing the steps per mm to 800 and it just sits there and hums
                                      Custom Core-XY
                                        If you replace your m584 command in config.g with just M584 X0 Y1 and nothing else do they work then?
                                        • samlogan87
                                          Tried that and still nothing. Sounds like it wants to move but it doesn't do anything unfortunately
                                          Custom Core-XY
                                            Can you send M906 and verify that the motor currents are being accepted?
                                            • samlogan87
                                              Sure can.
                                              Here they are
                                              M906
                                              Motor current (mA) - X:850, Y:850, Z:1850, U:1850, V:1850, E:800, idle factor 50%
                                              Custom Core-XY
                                                Phaedrux Moderator @samlogan87 last edited by
                                                This is why
                                                M911 S10 R11 P"
                                                M913 X0 Y0
                                                M913 is dropping current to 0%
                                                • samlogan87
                                                  You are an absolute genius. It works.
                                                  Thank you so much. I really love this forum
                                                  Custom Core-XY
                                                    Aww shucks.
                                                    Now maybe I can sleep because that was bugging me.
                                                    • whosrdaddy
                                                      whosrdaddy last edited by
                                                      Nice catch!
                                                      This one was bugging me too 🙂
