    Magball arm adapter
    Order discussion
    1134
    • boldnuts
      boldnuts last edited by
      Hi, is it possible to just buy the Smart Effector for delta pcb magball arm adapters on there own?
      • T3P3Tony
        T3P3Tony administrators @boldnuts last edited by
        @boldnuts the arms are made by Haydn Huntly he makes them in all sorts of lengths:
        https://plus.google.com/+HaydnHuntley
        www.duet3d.com
        • boldnuts
          Hi sorry I meant the pcb adaptors that you guys make that normally comes with the smart Effector
            If T3P3 doesn't have any spares, I have a set left over from prototyping. They don't have as many holes in them as the current production ones, but they have the 4 in a 20mm square for the carriage plus the 2 for the magballs.
            boldnuts 1 Reply Last reply Reply Quote 0
            • boldnuts
              boldnuts @dc42 last edited by
              @dc42 That would be great thanks, which would be the best way for me to purchase them from you, I am in the UK
                Please use the contact form at http://escher3d.com/pages/contact/contactindex.php.
                • fcwilt
                  fcwilt last edited by
                  Just out of curiosity why do need them?
                  • boldnuts
                    For a Tevo little monster, I have the smart effector but no adapters
                    fcwilt 1 Reply Last reply Reply Quote 0
                    • Danal
                      Danal last edited by
                      Using the "factory" adapters is fantastic idea.
                      If, and only if YOU want to do so, you can also print adapters that fit HWIN style carriages. Specifically, these are for 9mm belts. They would also work fine for 6mm belts.
                      https://www.thingiverse.com/thing:2795329
                      • fcwilt
                        fcwilt @boldnuts last edited by
                        @boldnuts said in Magball arm adapter:
                        If you are looking for adapters for rails in a delta I can provide you with a STL for the required spacing (or most any other spacing) and you could print your own.
                        • T3P3Tony
                          @boldnuts if you want to purchase the production version then please email info@duet3d.com otherwise getting a prototype from David should be cheaper.
                          www.duet3d.com
