    Duet 2 - Version Differences
    • Red Sand Robot
      Red Sand Robot last edited by
      Hello everyone,
      Planning on upgrading my current printer with a Duet 2 Wifi. I saw that there are two versions available now, with the newer being the v1.04 and the other being the v1.03, with the the older version being slightly cheaper.
      Would the v1.04 be worth the expense due to the addition of the mini blade fuses and the other changes mentioned in the revision? Trying to see if I can save a little money and not regret it.
      Thanks in advance!
      almost an engineer
      fcwilt T3P3Tony 2 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @Red Sand Robot last edited by
        @red-sand-robot said in Duet 2 - Version Differences:
        Hello everyone,
        Thanks in advance!
        If having the version with the fuses someday saves the board when you accidentally short something out, which might happen, you will be glad you spent the extra money.
        Be careful though, these Duets are addicting. I likes the results of upgrading my first printer so much I upgraded them all to Duet WiFi/Duex 5 combos. And I am happy as a clam at high tide - despite being somewhat the poorer for it.
        Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
        • RCarlyle
          RCarlyle last edited by
          I recently bought the 1.03 and am happy with it. I would suggest that a well-selected AC mains input fuse should be used with any board, but particularly one lacking full DC fusing, or when using a cheap DC PSU that might not have fully reliable overload protection.
          I feel ok with not having the onboard blade fuse because I have a 4A fuse on my 120VAC IEC plug inlet which will trip if there's a short in the AC wiring or the PSU draws more than 500w for a sustained period, and a genuine Meanwell 350w PSU which will trip and cut off power very quickly in the event of a DC short.
          So if my DC heatbed shorted, the PSU would trip very quickly, and if it failed to trip, the AC fuse would trip after maybe 5-10 seconds.
          • T3P3Tony
            T3P3Tony administrators @Red Sand Robot last edited by
            @red-sand-robot The fuses are added to comply with CE requirements, the other changes were to further reduce the EMI to make it easier for 3d pritner manufacturers to comply with the CE RED requirements. We discounted the 1.03 to clear the old stock. either should be fine for a printer upgrade.
            Duet Hardware Designer
            www.duet3d.com
            Red Sand Robot 1 Reply Last reply Reply Quote 0
            • Red Sand Robot
              Red Sand Robot @T3P3Tony last edited by
              @t3p3tony Thanks for the clarification! I haven't seen fuses on other replacement boards (mks gen, RAMPS, etc) before so I wasn't sure if they would be a deal breaker.
              almost an engineer
              • Jacotheron
                Jacotheron last edited by
                Also something useful on the Documentation where the changes are listed (https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_v1_Num_04), I understand that a probe and endstops could return higher voltages than only 3.3V (without damaging the board). This can be very useful when using something like a inductive probe that returns 5V (or some even slightly higher) without the need to construct an external voltage divider (though this is quite simple, but not plug and play).
                Am I understanding this correct, or should one simply avoid probes and endstops that return more than 3.3V?
                  dc42 administrators @Jacotheron last edited by dc42
                  @jacotheron said in Duet 2 - Version Differences:
                  You are correct. In practice the older Duets will tolerate more than 3.3V on the endstop and Z probe inputs too; but we are unable to guarantee this because Microchip doesn't specify a current rating for the ESD protection diodes in the microcontroller. In 1.04 we added external Schottky diodes so that we can guarantee it.
