    Can't connect to Wifi
    • Exerqtor
      Exerqtor last edited by
      Trying to do the initial setup on my Duet Wifi atm. I have just upgraded the firmware to "2.02beta", and all fine.
      But i can't connect to my wifi, here's what i get in Pronterface:
      Connecting...
      Printer is now online.
      M115
      SENDING:M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02beta1(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-08-12b5
      M587 S"Blabla 99" P"Blabla2"
      SENDING:M587 S"BLABLA 99" P"BLABLA2"
      M552 S1
      SENDING:M552 S1
      WiFi reported error: no known networks found
      WiFi module is idle
      I'm 100% positive that the wifi is 2.4GHz and that the SSID and password is typed right =/
      • Dougal1957
        Dougal1957 last edited by
        the prob is that pronterface will capitalise any character which is why the wiki says to set a macro up with the network details in it and to write that macro with a text editor that doesn't change anything.
        • Exerqtor
          Exerqtor last edited by Exerqtor
          It was that simple! Installed YAT an worked like a charm! Thanks so much, your a life saver!
          But i think what you just said should be noted in the " https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7 " tbh!
          • T3P3Tony
            T3P3Tony administrators @Exerqtor last edited by
            @exerqtor its mentioned in the guide:
            Duet Hardware Designer
            www.duet3d.com
            • Exerqtor
              Well i'm blind. That's what i get for just skimming thru what's written! ☠
              Never mind what i said over lol!
