    G28 Z Error: G0/G1: insufficient axes homed
    • Helder_Silva
      Helder_Silva last edited by Helder_Silva
      Hi and thanks in avance
      i have been struggling with this problem at some days .... i am new to duet boards .
      i have tried various configs but without sucess
      can someone help me
      Firmware Version: 2.01(RTOS) (2018-07-26b2)
      WiFi Server Version: 1.21RC4(08b3)
      Web Interface Version: 1.22.1
      i am using a NPN LJ18A3/8/Z-BX with the offsets x= 50 y =-10
      i am Making a upgrade on cr10s 300300400
      0_1534948848636_config.g
      0_1534948871379_homez.g
      Thanks in avance
      Helder Silva
      • Helder_Silva
        some pictures form interface to help
          Choose one of the following options.
          Home the x and y axis before you home z.
          Or add S2 to your G1 X Y movement before the g30 command so that it allows movement before the axis is homed.
          Or add M564 H0 to your config.g to allow axis to be moved before homing.
          Helder_Silva 1 Reply Last reply Reply Quote 0
          • Helder_Silva
            Helder_Silva @Phaedrux last edited by Helder_Silva
            @phaedrux said in G28 Z Error: G0/G1: insufficient axes homed:
            M564 H0
            Thanks for the help ... it moving in right direction now ,when we set for exemple +5mm it goes up 5 mm
            but wen tried homing z it goes up indefinitely and give this error
            M112
            M999
            Error: Homing failed
            the probe is wired to the z probe socket in duet board, not in the z endstop socket.... there is any problem ???
            thanks in advance
              In your printer, is it the bed that moves in the Z direction, or the print head?
              • Helder_Silva
                hi, its the print head that moves in direction of the bed... its a cr-10 s3 that i am trying to do upgrade...
                i think the problem its in the homez.g and eventually also in homeall.g. i gona try make the home.z more similar to homey.g or homex.g..
                thanks
                  See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z.
