    Pressure Advance Calibration
    187
    61.7k
    • avion23undefined
      avion23
      I've updated the *.py file with
      • preamble
      • postamble
      • klipper compatibility
      • Marlin compatibility
      advance_cal.py
      These are my results:
      Delta Fyling extruder PA 0 - 0.5 over 40mm PLA
      Delta Fyling extruder PA 0 - 0.5 over 40mm PLA carbon fiber
      • jim546undefined jim546 referenced this topic
      • duosvidundefined
        duosvid
        I have tuned PA according to the method in the wiki, not with the script, but by printing a 100mm cube and adjusting on the fly. I have settled on 0.7, with a bowden tube of around 480mm length.
        duosvidundefined 1 Reply Last reply Reply Quote 0
        • duosvidundefined
          duosvid @duosvid
          @duosvid said in Pressure Advance Calibration:
          overall surface and z-seam look better, I'm now getting gaps in the infill - not in the parameters though . .
            Phaedrux Moderator @duosvid
            It's not uncommon to need to increase perimeter overlap slightly after tuning pressure advance.
            • tmitch205undefined
              tmitch205 @dc42
              @dc42 said in Pressure Advance Calibration:
              Yes that's a valid approach. It's on our list to add a generator of pressure advance tests scripts to reprapfirmware.org, but it hasn't happened yet.
              I know this is a super old thread but wanted to check anyway. Has the generator been created and added? If so, could you provide the link, please?
                jay_s_uk @tmitch205
                @tmitch205 my version of the klipper one generated RRF compatible pressure advance tests https://jaysuk.github.io/Voron/PA/pressure_advance.html
                • symundefined
                  sym
                  Couldn't get this working, turns out Powershell encodes terminal output as UTF16LE. It will crash the Duet when you try to start it. Convert to UTF8 and smooth sailing.
                  Thanks!
                  • CNCModellerundefined CNCModeller referenced this topic
