    mm/s vs mm/min
    1301
    • fma
      fma last edited by
      I tried the latest release of Slic3rPE to be able to use the new 'send to duet' feature, and I noticed something weird.
      When I started the print, the head moved very very slowly. I discovered that Slic3rPR now add some limits, at the beginning of the gcode file:
      M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm
      M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec
      M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract
      M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
      M205 S0 T0 ; sets the minimum extruding and travel feed rate
      Problem: Duet M203 and M205 expect mm/min, not mm/s! Is it a bug in Slic3rPE, or do they really use mm/s in their firmware? What about others? Would be nice to all use the same units (mm/s would be better).
        Is that being added in a custom gcode field?
        It's been possible to add those speed values so that the print time estimate can be more accurate for a while now. They use mm/s. I've just added a semicolon to comment out the commands. The estimator still reads them.
        https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.1-alpha
        You can read about their print time estimator here
        • fma
          fma last edited by
          These values are defined under Printer settings. They can't be disabled, so you really need to enter the correct values, in mm/min, not in mm/s.
          • fma
            fma last edited by
            But they use M205 for jerk, not M566...
            • OBELIKS
              OBELIKS last edited by
              I hope they add a switch to use those values for the estimator only
              @Phaedrux Latest versions have a special page to set those. And no way to disable them. And if you put in 0 you get 0 in the gcode file.
              • fma
                fma last edited by
                I tried to set 0 too 😉
                  Oh that's too bad. I haven't looked at the newest version yet. I know they were adding some printer profile stuff. I wonder if there is a feature request open already to better support reprapfirmware.
                    Phaedrux Moderator @fma last edited by
                    @fma I just tried 1.41 and I can't seem to get it to generate the values like you describe.
                    Is there some checkbox I'm missing to get it to do this?
                    • fma
                      fma last edited by
                      Ok, I found it generates these lines if you use 'Marlin' flavor G-Codes (maybe with others, but I didn't try). No generation with RepRap/Sprinter.
                      BTW, Slic3rPE estimated the print to 3h, and it took 4h!
                      dc42 Phaedrux mrwizzard 3 Replies Last reply Reply Quote 0
                        Ah, that makes sense.
                          dc42 administrators @fma last edited by
                          @fma said in mm/s vs mm/min:
                          Have you tried running it in simulation mode?
                          • fma
                            fma last edited by
                            Nope... I will do that.
                              I've found that when I have the speed, acceleration, and jerk settings set to match the firmware the estimate is usually within 15 minutes of actual print time. Same with Cura.
                              • mrwizzard
                                mrwizzard @fma last edited by
                                @fma awesome, this works. I was removing the lines manually for the first two i did but figured i would look it up. Thanks for figuring it out 🙂
                                  Firmware 2.02RC3 supports the use of M205 to set jerk, in mm/sec.
