    Error: motor phase A and phase B disconnected on drivers 2
    18
    5370
    • Helder_Silva
      Helder_Silva last edited by
      i got this error but printer continues to print
      Firmware Version: 2.02RC1(RTOS) (2018-08-31b4)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.3
      0_1536240582136_console.txt
      just a example
      13:57:22: : Error: motor phase A disconnected on drivers 2
      13:57:17: : Error: motor phase B disconnected on drivers 2
      13:57:13: : Error: motor phase A disconnected on drivers 2
      13:57:08: : Error: motor phase B disconnected on drivers 2
      13:57:04: : Error: motor phase A disconnected on drivers 2
      13:56:59: : Error: motor phase B disconnected on drivers 2
      13:56:55: : Error: motor phase A disconnected on drivers 2
      13:56:50: : Error: motor phase A disconnected on drivers 2
      13:56:45: : Error: motor phase A disconnected on drivers 2
      13:56:40: : Error: motor phase A disconnected on drivers 2
      13:56:35: : Error: motor phase A disconnected on drivers 2
      13:56:29: : Error: motor phase A disconnected on drivers 2
      13:56:24: : Error: motor phase A disconnected on drivers 2
      13:56:19: : Error: motor phase A disconnected on drivers 2
      13:56:14: : Error: motor phase A disconnected on drivers 2
      13:56:09: : Error: motor phase A disconnected on drivers 2
      13:56:04: : Error: motor phase A disconnected on drivers 2
      13:55:59: : Error: motor phase A disconnected on drivers 2
      13:55:54: : Error: motor phase A disconnected on drivers 2
      13:55:48: : Error: motor phase A disconnected on drivers 2
      13:55:43: : Error: motor phase A disconnected on drivers 2
      13:55:38: : Error: motor phase A disconnected on drivers 2
      13:55:32: : Error: motor phase A disconnected on drivers 2
      13:55:27: : Error: motor phase A disconnected on drivers 2
      13:55:22: : Error: motor phase A disconnected on drivers 2
      13:55:17: : Error: motor phase A disconnected on drivers 2
      thanks in advance .
        That's a known issue with 2.02RC1 when motors move very slowly. You can either ignore the messages, or revert to 2.02beta1.
        Helder_Silva 1 Reply Last reply Reply Quote 0
        • Helder_Silva
          Helder_Silva @dc42 last edited by
          @dc42 thanks for the response ... i will ignore the indication
            I am trying to reproduce this issue so that I can fix it, but so far I have failed. So I would like a little more information:
            • Please post your config.g file.
            • I assume that driver 2 drives the Z motor. Are the messages generated during Z movement when changing layers, or when doing Z hop during travel moves, or when applying bed compensation to printing moves? Or during some other type of move?
              I have just release firmware 2.02RC2 and I am about to create a thread about it. Please can you upgrade to that release and see whether the messages have gone.
              • garyd9
                garyd9 last edited by garyd9
                FYI, I'm getting this same error on "2.02RC2(RTOS) (2018-09-07b2)"
                Only got it once, and really didn't even notice it until 10 minutes later. The printer wasn't printing anything at that time, but I might have been going through my "assisted manual leveling" routine. If so, and if it's in relation to my Z motor, my bed leveling routine does move Z slowly (for detecting a bltouch.) I didn't even see the error message until after I started a print (which is working fine.)
                Config.g is here: https://drive.google.com/open?id=1v9pR4ZOSNdoJxDbj4_IW-H9HO2PL0_oR
                bed.g is here: https://drive.google.com/open?id=15ya2fTVWHlyoPdo_iMwawhVKCId2HUlc
                and.. homeall.g is here: https://drive.google.com/open?id=153vnwFq9XBlJzI06V4ZoKemcK2k8DVzE
                I think those are all the files related. If you need more, please let me know.
                Take care
                Gary
                "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                • Helder_Silva
                  @dc42 Thanks for the followup in a few days i will test it
                  Good Work
                  • kuhnikuehnast
                    kuhnikuehnast last edited by
                    Get the same error on 2.02RC2(RTOS) (2018-09-07b2). Heated up the Hotend and the bed and Uploaded a file to print- then it happend. (Duet Wifi 2 v1.03 - on my other Duet, a v1.04 it didn't happen yet)
                    • Reckham
                      Reckham last edited by
                      the problem has been solved. - at least for me.
                      I had the same issue today:
                      It has been caused by wiring. I have seen that 1-2 of the 4 cables have been a little unloosen and the cable diameter had been reduced. This is why the motor hadn't had enough voltage and this caused the problem.
                      Check your wiring guys 😉
                      • madmattco
                        madmattco last edited by
                        Got a single line of motor failure just now.
                        https://puu.sh/CrHOD/b8e12dd972.png
                        https://puu.sh/CrHQa/96b01477be.png
                        https://puu.sh/CrHRb/4b31e2f123.g
                        • jckray
                          jckray last edited by
                          I have also been getting this error for both phase A and B on driver 2. Please let me know if there is any information I can provide to help get this bug fixed. The exact same message is present on all 4 of our printers with the same hardware running Firmware 2.02
                          John
                          Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
                          https://www.hydraresearch3d.com/
                            @madmattco and @jckray, please let me know:
                            1. Which Duet you are using;
                            2. What M906 motor current you are using on the motor(s) affected;
                            3. What motor(s) you are using;
                            4. @madmattco, please confirm that you are using firmware 2.02 release, not a RC version.
                            jckray madmattco 2 Replies Last reply Reply Quote 0
                            • jckray
                              jckray @dc42 last edited by
                              I am using Duet WiFi V1.04
                              Motor current is 320
                              Two Z motors in series rated at .4A (https://www.omc-stepperonline.com/linear-motor/nema-17-external-34mm-stack-04a-lead-8mm031496-length-300mm-17ls13-0404e-300g.html?mfp=181-lead-screw-length-mm[300])
                              Could this be an issue with low current motors, especially when in series? I plan to switch to 1A Z motors eventually.
                              John
                                Yes, I think it's caused by using 2 low current motors in series. Try connecting them in parallel to just one of the Z motor connectors (put the 2 jumpers back in the other) and double the current.
                                • madmattco
                                  madmattco @dc42 last edited by
                                  I'm running a maestro.
                                  All motors are set to 1 amp.
                                  The motors are on an anycubic kossel linear plus. to my knowledge the specs are as follows.
                                  Motor Type: Bipolar Stepper
                                  Voltage Rating:3.3V DC
                                  Rated Current/phase: 1.5A
                                  Phase Resistance:2.2ohms ± 10% (20 C)
                                  Step Angle: 1.8 deg.
                                  Phase Inductance:3.8mH ± 20%(1kHz 1V rms)
                                  I am running the 2.02beta2(RTOS) (2018-08-30b3)
                                    Upgrade your firmware to the 2.02 release.
                                    • JohnnyBeeGood
                                      JohnnyBeeGood last edited by
                                      Two weeks ago I had a shaft of a nema 17 break, so had to do some maintenance to my CoreXY.
                                      Was finished powered the Duet Maestro on and got this message:
                                      Warning: motor phase A may be disconnected reported by driver(s)
                                      Warning: motor phase B may be disconnected reported by driver(s)
                                      Gives it on all drivers.
                                      So had to find where this problems was coming from, config? firmware?, wiring?, nothing worked...
                                      So I have quite a few Maestro's had 3 from the fitforlauch campaign and had 2 whose U3 burnt out... still need to get the warranty on them.
                                      Hooked up a new Maestro and it worked.
                                      Two days ago on the same machine I had to rebuild the extruder, finished today and getting the same bloody error.
                                      I am running 2.02(RTOS) Motor Currents, M906 X1200.00 Y1200.00 Z1200.00 E1200.00 I70;
                                        dc42 administrators @JohnnyBeeGood last edited by
                                        I see that you've created another thread about this, so I will close this one.
