    M48 Measure Z Probe repeatability and print to serial output.
    Firmware wishlist
    12
    28
    6.4k
    • BoAundefined
      BoA @Phaedrux
      @Phaedrux Also... executing this G30 Px sequence causes printhead going outside of XY limits (which is understandable, as it allows to probe outside of bed area).
        Phaedrux Moderator @BoA
        @BoA Yes that is mentioned too.
        Caution: the XY coordinates are permitted to be outside the normal printable bed area! This is intentional, because some printers (e.g. delta printers) benefit from probing areas not used for printing.
        BoAundefined 1 Reply Last reply Reply Quote 0
        • BoAundefined
          BoA @Phaedrux
          @Phaedrux That is true, and it is acceptable and even desired, but ONLY if you specify X and Y. And probing "current location" by G30 P0 Z-9999 should not lead to "brrr-brrr-brrr" noise from steppers 🙂
          But perhaps this is just my opinion.
          • Leavundefined
            Leav
            This is similar enough that I don't think it warrants its own thread.
            Is there a way to use multiple probes per point and use the average of those measurement as the Z height for that point.
            The script above gives me pretty good deviation (±0.005mm, and it's consistant enough that I imagine this is a actually the stepper resolution), but I still feel like double or triple probing would be a better practice.
            Is there a way to do this today? do you think it's worth implementing?
            BoAundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            • BoAundefined
              BoA @Leav
              @Leav When You define z probe with M558 there are params:
              Snnn Tolerance when probing multiple times, default 0.03mm
              and
              Annn Maximum number of times to probe each point, default 1.
              This probes until results are within defined tolerance.
              Not sure if this does averaging measurements tho
              Leavundefined 1 Reply Last reply Reply Quote 1
              • Leavundefined
                Leav @BoA
                @BoA
                Thanks! (link to g-code reference page)
                The A and S parameters control multiple probing. Probing is repeated until two consecutive probe attempts produce results that differ by no more than the S parameter; then the average of those two results is used. However, if the number of attempts specified by the A parameter is reached without getting two consecutive results within tolerance of each other, no further probe attempts are made and the average result of all the attempts is used.
                Looks like I could manipulate this to do exactly what I wanted! (1 femtometer repeatability goal, here I come!)
                • fcwiltundefined
                  fcwilt @Leav
                  @Leav said in M48 Measure Z Probe repeatability and print to serial output.:
                  Using a S parameter of -1 results in averaging the number of readings specified by the A parameter.
                  • ignacmcundefined
                    ignacmc @dc42
                    @dc42 If I use the macro:
                    M291 P"Probe will be tested 10 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                    G28
                    M401
                    G30 P0 X151 Y161 Z-9999
                    G30 P1 X151 Y161 Z-9999
                    G30 P2 X151 Y161 Z-9999
                    G30 P3 X151 Y161 Z-9999
                    G30 P4 X151 Y161 Z-9999
                    G30 P5 X151 Y161 Z-9999
                    G30 P6 X151 Y161 Z-9999
                    G30 P7 X151 Y161 Z-9999
                    G30 P8 X151 Y161 Z-9999
                    G30 P9 X151 Y161 Z-9999 S-1
                    M402
                    It probes on the center of the bed X=0, Y=0 (I am using a Delta). Shouldn't it probe on X=151, Y=161????
                    Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
