A few questions regarding switching to Duet
  • https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
    This should get you going on the BLTouch.
    https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
    And if you have issues.
    For bed compensation and leveling you can use bed.g. That gets called by G32. If you have a paneldue there is also a button on the screen that will call it. It can also be ran from the DWC.
  • @phaedrux Thanks for that I will try to get that sorted out this weekend.I am very new to all of this so when setting up a cartesian style printer where the extruder's home position is in the lower left hand corner and the actual nozzle sits below and to the left of the actual bed how or what offsets need to be changed?I am assuming the simplest way of setting those up would be to accurately measure them and entering them as a negative into wherever the offsets are set?
  • Oh and this will help a lot with getting the bed and axis travel limits setup.
    https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html?m=1
  • I am Following the documentation to set up my machine and Duet but when using a BlTouch is it recommended to not use a Zmin endstop? I am asking because I have both wired up at the moment and I figured I would ask if it is common practice to eliminate the Zmin endstop when using the BlTouch sensor?
  • @siblues the BLTouch would become your z min endstop. Your homing files would need to be changed to use a G30 probe command instead of a G1 S1 Z move to trigger the endstop switch.
    You could move the endstop switch to z max. Sometimes it's handy to be able to home to z max as well.
  • I have a cartesian style printer and setting it up at z max would be problematic when it comes to wiring it up.I am having a bit of a hard time setting up the bltouch and it is due to my lack of experience in using any type of firmware.I ran into the same problem when trying to set up my Smoothie and I couldn't get it to work for the life of me.I can care less if I have a zmin endstop or not as long as everything works as it should.I already have the zmin wired up but I can remove it if necessary to clean things up a bit. The problem I have is it isn't as simple as using the configurator to set up the machine and then copying and pasting the relevant lines of code for the bltouch sensor into the correct folders is it?
    Which way would you recommend for an absolute beginner?The simplest route would be a better option for me at the moment.
  • @siblues can you post your current config.g and homing files? Also the deployprobe and retractprobe files.
    What firm ware version are you using?
    I can take a look and see if anything else needs changing.
    There are 5 wires for the BLTouch. They need to go to the right place and the wires and crimps need to be working obviously. Wiring ends up being the culprit often. A multimeter to check continuity is helpful.
    @siblues said in A few questions regarding switching to Duet:
    It's entirely up to you whether you home Z using the Z probe or using an endstop switch. Set up the homing files according to your choice. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z.
    Having the option to home to Z max can be useful if you want to be able to resume a print after a power failure.
  • I have the BlTouch wired up how it is pictured here
    firmware version
    2.0(RTOS) (2018-06-05b3)
    config.g
    ; generated by RepRapFirmware Configuration Tool on Tue Oct 30 2018 20:32:38 GMT-0400 (Eastern Daylight Time)
    M550 PTony's P3 Steel ; Set machine name
    M551 ; Set password
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X80 Y80 Z400 E420 ; Set steps per mm
    M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X220 Y220 Z200 S0 ; Set axis maxima
    M574 Y1 Z1 S0 ; Set active low endstops
    M574 X1 S1 ; Set active high endstops
    M307 H8 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X0 Y0 Z5 ; Set Z probe trigger value, offset and trigger height
    M557 X15:205 Y15:205 S20 ; Define mesh grid
    M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M143 H1 S290 ; Set temperature limit for heater 1 to 290C
    M106 P1 S1 I0 F500 H0:1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H0:1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    deploy probe
    ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P7 S10 I1
    retract probe
    ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P7 S90 I1
    home all
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 S1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 X5 Y5 F6000 ; go back a few mm
    G1 S1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G1 S1 Z-205 F1800 ; move Z down stopping at the endstop
    G90 ; absolute positioning
    G92 Z0 ; set Z to axis minimum (you may want to adjust this)
    ;G91 ; relative positioning
    ;G1 S2 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
    Home x
    ; homex.g
    ; called to home the X axis
    G1 S1 X-225 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 X5 F6000 ; go back a few mm
    G1 S1 X-225 F360 ; move slowly to X axis endstop once more (second pass)
    G1 Z-5 F6000 S2 ; lower Z again
    home y
    ; homey.g
    ; called to home the Y axis
    G1 S1 Y-225 F1800 ; move quickly to Y axis endstop and stop there (first pass)
    G1 Y5 F6000 ; go back a few mm
    G1 S1 Y-225 F360 ; move slowly to Y axis endstop once more (second pass)
    home z
    ; homez.g
    ; called to home the Z axis
    G1 S1 Z-205 F1800 ; move Z down until the endstop is triggered
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
  • If you're wired up the way its shown in that diagram you've got the wrong heater pin unbound. You've got 8 instead of 7 in M307.
    Heater pin 3 is also commonly used. Either way, check your config-override.g to see if there is a heater binding being applied after you've removed it.
  • You'll also have to modify your homeall and home z files to use G30 instead of G1 S1 Z-200
  • Thanks for all the help so far Phaedrux
    I have no idea where the config-override.g file is.I checked in the settings / system editor where all of the other folders are but it isn't there.
    I would like to ask if I am using G30 to replace the entire line G1 S1 Z-200 or just replacing the G1 line with G30 S1 Z-200.
    I am guessing the way I am setting it up now with your guidance is to use both the Zmin endstop and BlTouch?
  • @siblues You may not have one. It'll only be created if you've used M500 to save a parameter. Similar to how older firmwares use EEprom saving. M501 is used in config.g to load it.
    G30 will replace the entire G1 line. It tells the firmware to find z min with the probe.
  • Phaedrux after I changed things around how you pointed out how do I go about checking to see if the probe is actually working as it should?
    I tried
    M280 P7 S10 I1
    M280 P7 S90 I1
    The BlTouch is going through the self test at startup and then gives a constant on led.
  • What happens when you send those command? Does the pin deploy and retract?
  • No it doesn't move I even tried both codes without the l1 just to check.
  • I hope I didn't destroy this board but it was working fine and after adjusting a few things in the config now the only thing I can get the board to do is heat the bed.I get this error message whenever I try to move any of the axis
    M120
    G91
    G1X-1 F6000
    M121
    G0/G1 insufficient axes homes
    error pop
  • Add a S2 to the end of the G1 gcode line. You can't move an axis before homing.
  • Please excuse my very limited know how on the subject but what I posted was the error message that popped up where would I need to add that S2?What folder because I looked and I don't see that anywhere?
