    Flashforge Creator Pro Heat bed wiring
    flashforge heat bed
    • emax
      emax last edited by emax
      almost finished wiring of my Flashforge Creator Pro 2016. I am struggling with the Heat bed temp Sensor. I thought it was a thermistor, but there are 4pin connectors. On the bed, it says +3,3, GND and SIG (see picture) Where are the cables going in the duet? Can you give me a hint? Thanks a lot.
      Bigger picture heat bed
      Another view
      • garyd9
        garyd9 last edited by
        See:
        https://groups.google.com/d/msg/flashforge/4lYQXPe_fA8/ga__vm05AwAJ
        (flashforge google group) It'd be worth your while to read the entire thread at the link, as it chronicles me converting my FFCP to use a duet.
        Text at the link is:
        Uh oh... For the HBP thermistor, it's 4 wires. I'm not sure how to handle that when most things only expect 2 wires for a thermistor. I know some specialized temp probes use 4 wires (PT100, for example), but this isn't supposed to be that fancy. Any suggestions? (Of course, I'll be googling as well...)
        I believe two of them are ground or one is a "no connection". The
        wiring is often an MPC-4 CD ROM audio connector. They are either 4
        or 3 wires. For 3DP, the 3-wire variant is used. But you can use
        the 4 wire variant as well: the 4th wire is just not connected to
        anything.
        See this https://www.flickr.com/photos/d-newman/14557870172/in/album-72157645313526624/
        • emax
          emax last edited by
          Thanks a lot, good thread. However, I am not that advanced yet in electronics, so I would like to check, if I can wire it like shown below? Or do I have to buy the OSH Park board?
          • garyd9
            garyd9 last edited by garyd9
            The very next post in the thread I linked contained the following:
            On the HBP thermistor: I found something that indicated that only pins 1 and 2 on the board are significant (numbering the pins left to right with the PCB printing face up.) It's the thermistor, so no polarity issues.
            HBP: Heated Build Plate
            PCB: Printed Circuit Board
            Here's the tricky part, and the reason I can't (and won't) answer you directly: There are dozens of variants of the flashforge creator pro. Even "true" flashforge printers have changed parts over time - often without making much sense. There are labels on the PCB image you posted, but due to the angle I can't quite read one of them (starts with an "s") and can't figure out which pins are labeled what.
            Most likely, the pin on the far side with the label that starts with an "S" is your SIG (signal) and the middle two pins are GND (ground.) If that's the case, you should be able to use the wires for the S and the adjacent ground.
            If you have a multimeter, you can use it to verify which pins are the thermistor. (google for "how to use a multimeter to measure a thermistor")
              dc42 administrators @emax last edited by
              @emax said in Flashforge Creator Pro Heat bed wiring:
              It may not matter, however I would swap the two red wires in your diagram, so that Signal goes to Thermistor0 and Gnd goes to VSSA.
