    Duet 2 Ethernet network issue?
    • TLeTourneauundefined
      TLeTourneau
      I have a new Duet 2 Ethernet (firmware 2.01) that I have attached to a Tronxy X5S (core XY) that has been converted to 24v. I had updated the firmware and configured the ethernet prior to installing the board and everything seemed fine. Once I had changed the connectors using the provided items I installed the board and connected the X, Y, Z stops, stepper motors, thermisters, and fans. I have left the heating elements disconnected, they will be going through MOSFET's.
      Once I installed the board powered up and I connected to it through the web interface. I seemed fine and the temps were reading from the thermisters. At that point, as a test, I selected to home Y, it moved the carrage to the Y stop but was drifting on X while it did it. Once done I lost connection to the Duet 2, there is no connection or activity indicators on the Duet's newtork adapter. Power cycling hasn't had an impact. I will be connecting to it with USB when I get home to see what I can determine but I wanted to see if anyone has any recommendations. I started by using a configuration from https://www.youtube.com/watch?v=6nqddfxHla0. The config.g from there is:
      <code>
      ; generated by RepRapFirmware Configuration Tool on Mon Jul 23 2018 19:43:29 GMT-0500 (Central Daylight Time)
      M667 S1 ; Select CoreXY mode
      M550 PTronxy X5S ; Set machine name
      M552 S1 ; Enable network
      M587 S"BCWireless" P"thisismyhouse" I192.168.1.187 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80 Y80 Z400 E98 ; Set steps per mm
      M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z180 E1500 ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z100 E10000 ; Set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Set active low endstops
      M558 P0 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:315 Y15:315 S20 ; Define mesh grid
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      </code>
      I did modify the network section to remove the wifi data and set a static IP that had held through several reboots.
      • deckingmanundefined
        deckingman @TLeTourneau
        @tletourneau I'm a bit confused. You say the board is Duet Ethernet yet your configuration is for a Duet WiFi.
          TLeTourneau
          This post is deleted!
            TLeTourneau
            @deckingman said in Duet 2 Ethernet network issue?:
            @deckingman I modified the network section to remove the wifi data and set a static IP that had held through several reboots. I'm at work so I do not have access to my config.g so I listed the one I based mine off of.
              TLeTourneau
              It was me, I somehow connected the endstop micro-switches incorrectly. Now I just need to figure out why X and Y move when I move just one of them (either one). On the plus side Z seems fine. 🙂
                Phaedrux Moderator @TLeTourneau
                @tletourneau Use this guide to check your motion.
                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
