    Cannot open telnet connection
    678
    • hevilp
      hevilp last edited by
      I have:
      13:04:45M586
      HTTP is enabled on port 80
      FTP is enabled on port 21
      TELNET is enabled on port 23
      Using DWC runs fine, FTP connection runs.
      Why I cannot connect with Telnet?
      • T3P3Tony
        T3P3Tony administrators @hevilp last edited by
        @hevilp how are you connecting? maybe your network is blocking port 23 (although that you be odd on a local network)
        • adavidm
          adavidm last edited by
          Is your windows client defaulting to ssh?
          • hevilp
            hevilp last edited by hevilp
            I'm in my LAN, so how port 23 should be blocked? FTP connection is working right.
            Defaulting to SSH? How?
            When I use port 23 in putty, how it should be "defaulting" to ssh?
            • adavidm
              You have to change the port and protocol. You've probably done both, as the "Telnet" label is pretty prominent, but Putty does default to SSH IIRC and it's easy to overlook.
              • T3P3Tony
                T3P3Tony administrators @adavidm last edited by
                @hevilp this works for me:
                What version of the firmware are you using
                • hevilp
                  No, right options, I'm using putty for over 17 years.....
                  Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
                  Firmware Elektronik: Duet WiFi 1.02 or later
                  Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
                  WiFi Server Version: 1.21
                  Web Interface Version: 1.22.3
                  pi@Repetier-Server:~ $ nmap 192.168.1.141
                  Starting Nmap 7.40 ( https://nmap.org ) at 2018-10-21 12:07 UTC
                  Nmap scan report for 192.168.1.141
                  Host is up (0.0065s latency).
                  Not shown: 997 closed ports
                  PORT STATE SERVICE
                  21/tcp open ftp
                  23/tcp open telnet
                  80/tcp open http
                  Nmap done: 1 IP address (1 host up) scanned in 3.46 seconds
                  • T3P3Tony
                    T3P3Tony administrators @hevilp last edited by T3P3Tony
                    @hevilp I am using the slightly more recent RC for firmware version 2.02 (RC3) and the latest DWC, however I don't think that would cause this issue.
                    Can you try dropping the Telnet service and starting it again:
                    M586 P2 S0
                    M586 P2 S1
                    If that does not work then maybe do a firmware upgrade to the latest RC just to be sure.
                    edit: I just checked and you can only have 1 telnet session open, could it be you have multiple sessions?
