Leveling the bed...
@tletourneau said in Leveling the bed...:
Just an update, I think I figured out my issue resetting the BLTouch. I was doing a M280 P7 S160 and I needed to do a M280 P7 S160 I1 because I am using the heater 7 connection without an expansion board connected. My readings are still odd, here is what I am doing: The process I used is: power on the machine, input the G92 X20 Y20 Z20 so I can leave the head in the same spot, set the bed to have a light drag on a piece of 20lb paper and run the G92 Z0 and then the G30 S-1. The G30 S-1 command seems to raise the bed at the end, should it? That might make it hard to achieve repeatable results.I've installed anti-backlash nuts on the bed and a 330x330x3mm borosilicate glass plate with an interface between the glass and the bed of a sheet of 0.5mm high temp silicone rubber.
Here are the results:
BLTouch on glass:
-0.598
-0.610
-0.587
-0.645
-0.582BLTouch with blue painters tape on glass:
-0.585
-0.605
-0.600
-0.600
-0.587
-0.600I entered the following commands between each iteration:
G92 Z0
G30 S-1
M280 P7 S160 I1Again, I noticed the bed raising after the probe took it's reading whenever the G30 S-1 was executed.
I am including my config file in case that helps:
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 16 2018 15:16:22 GMT-0600 (Central Standard Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M667 S1 ; Select CoreXY mode ; Network M550 P"Tronxy X5S" ; Set machine name M552 P192.168.0.95 S1 ; Enable network and set IP address M553 P255.255.255.0 ; Set netmask M554 P192.168.0.1 ; Set gateway M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S0 ; Drive 3 goes backwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E98.00 ; Set steps per mm M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2) M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X330 Y330 Z400 S0 ; Set axis maxima ; Endstops M574 X1 Y1 S0 ; Set active low endstops ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch M558 P9 H5 F100 T6000 A5 R0.3 S0.005 B1 ; Set Z probe type to bltouch and the dive height + speeds G31 P25 X-42 Y-4 Z0 ; Set Z probe trigger value, offset and trigger height M557 X15:315 Y20:315 S20 ; Define mesh grid ; Heaters M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic power saving M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ; Custom settings M591 D0 P1 C3 S0
I'm going to run a mesh grid and see what I get, I've set the sensitivity back to 0.005.
I don't suppose you could post a video showing the behaviour of the probe?
Well, it's better and running with a sensitivity of 0.005 again. I'll try to fine tune it tomorrow and run a 240 point mesh and see how it goes.
@phaedrux I'll make one tomorrow and post it.
