    8 stepper motors, 4 servos and a display
    • taconite
      taconite last edited by
      Hello guys,
      I want to build a Delta-style printer with multiple printheads and I am afraid the pinout of the duet did´t make much sense to me.
      what I need:
      1x stepper motor for x tower (+ endstop)
      1 x stepper motor for y tower (+ endstop)
      1 x stepper motor for z tower (+ endstop)
      1 x stepper motor for E0 (+ heater)
      1 x stepper motor for E1 (+heater)
      with the duetx5:
      1 x stepper motor for E2 (+heater)
      1 x stepper motor for E3 (+heater)
      1x stepper motor for E4 (+heater)
      makes a sum of 8 stepper motors. So I guess with the extension board that is possible. Furthermore for my application I need:
      option 1: I need at least 2 servos in combination 2 more stepper motors (+endstops) (that would be driver E5 and E6), as stated in the duet wiki I could use Heater E7 for 1 servo and 1 Fan (I just need 1 PWM Fan for the partcooling fan) for the other servo.
      option 2: 4 servos, Heater E5 and Heater E6 as servos aswell.
      The last thing would be a Display connected via CONN_LCD
      Is this correct and possible?
      One thing that is kind of confusing is the pin numbers... is there a system (hardware pins vs. firmware pins)?
      Thanks for your help
        That's all possible except that CONN_LCD does not support a display. It was originally intended to support a 20x4 text display, but was repurposed to support 2 extra stepper motors and endstop switches.
        You can connect a PanelDue touch screen to the dedicated connector for it, or to the CONN_SD connector.
        Unless you have a reason to modify the firmware, you only need to know the logical pin numbers used in M42 and M280 command, which are listed at https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers.
        • taconite
          @dc42 perfect, thank you!
          • T3P3Tony
            T3P3Tony administrators @taconite last edited by
            @taconite I am fascinated how you will mount or tool change the 5 extruders on a delta.
            taconite 1 Reply Last reply Reply Quote 1
            • taconite
              taconite @T3P3Tony last edited by
              @t3p3tony said in 8 stepper motors, 4 servos and a display:
              As because this is an entire new idea, I will update you as soon as it is "safe" 😉
