Inductive sensor - Z probe returning wrong measurements
My Duet controlled machine
2.3k
  • undefined
    Do you have anything connected to the temperature daughter board connector? Do you have a DueX expansion board connected?
    • undefined
      3d_druck
      No. I did not use any of them. I have a duet Ethernet and expansion header for the drivers. Thats it.
      • undefined
        Please try it without the expansion board ribbon cable connected to the Duet, in case of a problem with the cable or the expansion breakout board.
        • undefined
          3d_druck
          I tried and it did not work.
          I got a new TFT panel display same one and the sd card works fine. So i think its the problem with sd card port in the previous panel.
          Thanks for the swift response and support!
          21 out of 24
