    Can I store and read values from card
    1131
    • core3d.tech
      core3d.tech last edited by
      I would like to be able to store and read custom parameters from disc and use them in macros. Any way to do this?
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @core3d.tech last edited by
        @core3d-tech I use a couple of macros to change the z offset between PLA and PETG. If I need to change the offset, I only need to edit the macro.
        core3d.tech 1 Reply Last reply Reply Quote 0
        • core3d.tech
          core3d.tech @Stephen6309 last edited by
          @stephen6309 I need to store information on state of the printer when it turns/off on. Something similar to XYZ location in case of power outage.
          • deckingman
            deckingman @core3d.tech last edited by
            @core3d-tech said in Can I store and read values from card:
            Have you seen this ?
            https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
            • core3d.tech
              core3d.tech @deckingman last edited by core3d.tech
              @deckingman Clearly that procedure stores a bunch of information, but I don't see what information it chooses to store and I want to store something completely unrelated. I have a feeling all that is coded under the M911 code in the firmware itself.
              I'll give a completely non-related example to illustrate (not what I'll be using it for); Lets say I want to store the latest RGB (LEDs) values so next time I start up my Printer it resumes at those RGB values.
              So I would need something that says M???? "RGB:...,...,...."
              At a later stage I want this information back and use it (as I'm typing this I get the feeling this is way beyond G-code/MAcro. sigh, still any suggestions...
                It's possible in a macro file to create and write data to a different macro file using the M559 command. Then you could execute the file from config.g. So you could use this method if you used only a few different settings of the RGB LEDs. When conditional GCode, variables and the object model are implemented, you will be able to do a lot more.
                timcurtis67 core3d.tech 2 Replies Last reply Reply Quote 1
                • timcurtis67
                  timcurtis67 @dc42 last edited by
                  @dc42 said in Can I store and read values from card:
                  👍 👍 Can't wait for this option. ☺
                  • core3d.tech
                    core3d.tech @dc42 last edited by
                    @dc42 that latter sounds awesome. Any chance that's in place prior to MRRF2019?
                      dc42 administrators @core3d.tech last edited by
                      When is that?
                      • core3d.tech
                        @dc42 March 29th 2019 (Goshen Indiana) https://www.eventbrite.com/e/2019-midwest-reprap-festival-mrrf2019-tickets-51075814135
                          Yes, I expect it to be available before then.
                          • core3d.tech
                            @dc42 Any chance, rudimentary math available (like Build height = Build height - x)?
                              Yes.
                              • core3d.tech
                                @dc42 Excellent! People will ask why do you do this with your printer. It makes no sense and I'll say "because Duet lets me!!"
                                • Googliola
                                  Googliola last edited by
                                  @core3d-tech In case you have missed the discussion about variables I kicked off a while ago.
                                  dc42 posted a first draft of the intended implementation here , I haven't had proper time to comment on yet ;-(
