    Consistent layer shifting in the X direction [SOLVED]
    1998
    • mrjoneskod
      mrjoneskod last edited by dc42
      Layer Shifting only in the X-axis.
      Hello, I have a Cartesian printer (ultimaker style), used my old ramps and never had the layer shifting problem.
      Is only in the X direction. The motors are the same for all axis. My steppers are https://www.amazon.ca/Longruner-Connector-Mounting-Brackets-LD10-3/dp/B07FKCCD8Q/ref=sr_1_8?s=electronics&ie=UTF8&qid=1541126467&sr=1-8&keywords=longruner+stepper+motor, they are usually really good.
      I really don't know what could be the cause and would like some help, the problem started after I replaced the RAMPS for the Duet WIFI. I Understand that that Duet is miles better, but I have no idea what the root cause could be.
      Any help will be highly appreciated.
        Can you post your config?
        Is it a consistent layer shift in the same model or is it on all models?
        If you move the print head by hand with the motors disconnected is it smooth?
        mrjoneskod 1 Reply Last reply Reply Quote 0
        • LHelge
          LHelge last edited by
          I've had that problem when the setscrews on the X motor pulley were loose. Could be worth checking.
            Aside from loose pulleys and other mechanical issues, here are some possibilities:
            • X motor current set too low in config.g (M906 command)
            • X motor current set correctly, but you are using M913 to reduce it (e.g. in a homing file) and you have forgotten to restore it to 100%
            • X acceleration set too high in M201
            • X speed set too high in M203
            • X jerk set too high in M566
            • mrjoneskod
              mrjoneskod @Phaedrux last edited by
              @phaedrux
              Hi, it happens in all models. When I said consistent I meant persistent. It happens on every print. Usually more in the first layers. When the shifting is not too bad I let the print go on and sometimes I get usable prints.
              I have already checked all pulleys, and they are firm in place. The movement is not silky smooth but there is little resistance as it always been.
              I really don't know what could be happening.
              My config is:
              *****; Configuration file for Duet WiFi (firmware version 1.21)
              ; generated by RepRapFirmware Configuration Tool on Sun Sep 30 2018 14:31:59 GMT-0500 (Central Summer Time)
              M550 PStaplestain [8'| ; Set machine name
              M552 S1 ; Enable network
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M92 X80 Y80 Z400 E140 ; Set steps per mm
              M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
              M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
              M906 X1200 Y1200 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X250 Y200 Z250 S0 ; Set axis maxima
              M574 X1 Y1 S0 ; Set active low endstops
              M558 P5 I1 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
              G31 P500 X34 Y3 Z2.23 ; Set Z probe trigger value, offset and trigger height
              M557 X15:235 Y15:185 S20 ; Define mesh grid
              M563 P0 D0 H1 ; Define tool 0
              ; LED
              M307 H2 A-1 C-1 D-1 ; disable the heater functionality
              ; Custom settings are not configured*****
              Thanks for helping.
              • mrjoneskod
                That is my Z homing file:
                G91 ; relative positioning
                G1 S1 X-255 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X5 F6000 ; go back a few mm
                G1 S1 X-255 F360 ; move slowly to X axis endstop once more (second pass)
                G1 Z-5 F6000 S2 ; lower Z again
                G90 ; absolute positioning
                  Can you send M906 in the console to see the actual currents being used. Same with M913 to see if it's being reduced at all.
                  mrjoneskod 2 Replies Last reply Reply Quote 0
                  • deckingman
                    deckingman last edited by deckingman
                    Also check the wiring on the X motor lead. It could a bad crimp on one of the pins which might have got disturbed when you changed the boards.
                    • mrjoneskod
                      @phaedrux I am trying to run a ~2h print. I sup[ose I have to wait to run the m906 and m9013 correct?
                      • mrjoneskod
                        mrjoneskod @deckingman last edited by
                        @deckingman Yeah, I am starting to think about wiring as well. Maybe I need a better crimper.
                        • mrjoneskod
                          @phaedrux
                          5:15:22 PM
                          M913
                          Motor current % of normal - X:100, Y:100, Z:100, E💯100💯100💯100💯100:100
                          5:15:13 PM
                          M906
                          Motor current (mA) - X:1200, Y:1200, Z:800, E:1200:1200:1200:1200:1200:1200:1200:1200:1200, idle factor 30%
                            You can send M codes with no parameters to get the duet to tell you what the current values are. You can send them any time.
                            Looks like your motor currents are ok. You could try increasing your x motor current to 70-85% of the motors rated max just incase it needs more power than its getting.
                            Is there any over extrusion going on that could cause the nozzle to catch?
                            • mrjoneskod
                              I don't see any over extrusions. About increasing the current. I tried it. It did not solve the problem but cause the motor to run really hot. Hot to the point I could not touch for more them 3 seconds.
                              I did calibrate my extrusion length using the matter hackers guide, so I think it is ok on that.
                                There's a small chance that it could be caused by a partially-blown stepper driver. To eliminate that possibility, if your E1 stepper output is free than you can connect the X motor to that instead. Then add the command M584 X4 E3 to config.g, earlier in the file than the M906 command and the M350 command if you have one. Also make sure that the M569 P4 command specifies the same direction (S parameter) as the M569 P0 command.
                                • mrjoneskod
                                  mrjoneskod @dc42 last edited by
                                  @dc42 DO you really think that could be it? I will try to re-do the connector and realign the gantry first.
                                  My Duet is brand new, I never forced it, it has active ventilation and I never exceed the driver nor the motor max current. I really think it is either software or mechanical.
                                  Like I said, after the couple shifts in the first 10 to 20 layers the other 200 go absolutely fine.
                                  that is what's really throwing me off. Being my printer an ultimaker style the gantry does no move up ir down, only the bed.
                                  I will do the adjusts and post the results.
                                  • mrjoneskod
                                    @dc42 SOmething I forgot to mention, yesterday I managed to complete 2 successful prints (no major shifts), but the weird thing is on the second one the 4 top layers were missing but the printer reported the end of print with no errors.
                                    Could that be a case for reflashing the firmware?
                                    I am on 1.21 (2018-03-21)
                                      That firmware is quite old so I suggest you update it to latest stable or latest release candidate.
                                      • mrjoneskod
                                        @dc42 said in Consistent layer shifting in the X direction:
                                        o latest s
                                        So I have updated the firmware, but nothing changed, I removed and tested each bearing. They all seem fine, there is one thing tho. the x-axis will move very smoothly in one direction and there is a lot of resistance in the other direction.
                                        I have no clue what could cause that. If I try to move it by hand in one direction it will move with barely any force, in the other direction if I dont move it trough the sliders it almost bend the 8mm rods of the gantry.
                                        Any ideas?
                                        nophead 1 Reply Last reply Reply Quote 0
                                        • nophead
                                          nophead @mrjoneskod last edited by
                                          @mrjoneskod That does sound like a faulty linear bearing. I think they can get a flat ball if you run without lubricant but it has to move about twice the length of the bearing to find it and jam.
                                          • mrjoneskod
                                            mrjoneskod @nophead last edited by
                                            @nophead Well, I will buy new bearing and see what happens
                                            • mrjoneskod
                                              mrjoneskod @mrjoneskod last edited by
                                              @mrjoneskod Well changed all the bearings. The movement sure goes smoother, but not a lot more.
                                              The problem is still happening ☹
                                              • mrjoneskod
                                                Today I decided I would find out for good what was it that was holding me up. I decided to try everything so I changed the X and Y connectors and my Y started shifting (Still my X physically), so I knew it was not the driver, I decided to try to realign every single belt, pulley nut and bolt. Still did not do it. So I decided to change the motor, as I have spare ones, and as I was doing so I found the cause: "a broken motor mount" the motor shaft what quite misaligned in relation to the X rod it was connected to and the excessive momentum was causing it to bind! I have steel mounts the old ones are aluminum, put the steel mount carefully aligned it and tension the belts, and BINGO! Everything is back to normal!
                                                Thanks a lot for the help guys! I really appreciate it!
