[Solved] Multiple independent Z motors and Motor current
  • Hi
    I set up 2 z motors for the bed leveling using using
    M584 X0 Y1 Z2:4 ; Two Z motors connected to driver outputs 2 and 4
    However i realized that the Z4 Motor was getting a lot hotter than the Z2 Motor.
    The current was configured
    M906 X1200 Y1200 Z800 E1200 I30
    But it seems that the Z800 only applies to Z2 and not Z4
    I had to issue
    M906 X1200 Y1200 Z800 E1200:800 I30
    and now Z4 stays cool as well.
    is this intended behaviour? as it not what i would have expected.
    The entry for M584 on the GCodes wiki page states that you must put the M584 command earlier in config.g than several other commands, including M906.
  • thanks dc
    but the command is before the others
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P4 S0 ; Drive 4 goes backwards (Z2 in the E1)
    M569 P0 V118 ; Stealthchop2 till about 78 mm/sec
    M569 P1 V118 ; Stealthchop2 till about 78 mm/sec
    M569 P2 V118 ; Stealthchop2 till about 78 mm/sec
    M569 P3 D2 ; Extruder in Spreadcyle
    M569 P4 V118 ; Stealthchop2 till about 78 mm/sec
    M92 X80 Y80 Z1600 E414 ; Set steps per mm
    M566 X900 Y900 Z12 E240 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z180 E3000 ; Set maximum speeds (mm/min)
    M201 X3000 Y3000 Z250 E10000 ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M671 X-75:295 Y110:110 S0.5 ; leadscrews at mid left, and mid right
    Issuing M906 Produces
    Motor current (mA) - X:1200, Y:1200, Z:800, E:1200:1200:1200:1200, idle factor 30%
    So the second Z is at 1200 mA.
  • Don’t you need to set the current, speeds, accelerations, jerk and steps per mm for the other axis by assigning it to a different axis. I think the next one is U. There is a section about setting up multi z axis and it explains it there. I can post an excerpt from my config file when I get back to my computer it a couple of hours. I am running 4 z motors
    See the part of https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping that is emphasized in bold text.
  • @Veti
    Here is an excerpt from my config. This is when I was running the three z axis motors
    M569 P0 S1 ; Drive 0 goes forwards X Axis
    M569 P1 S0 ; Drive 1 goes forwards Y Axis
    M569 P2 S0 ; Drive 2 goes forwards Z Axis FL
    M569 P3 S1 ; Drive 3 goes forwards Z Axis RC
    M569 P4 S0 ; Drive 4 goes forwards Z Axis FR
    M569 P5 S1 ; Drive 5 goes forwards Extruder
    ; Motor remapping for dual Z
    M584 X0 Y1 Z2:3:4 U3 V4 E5 P5 ; Driver 0 For X, 1 for Y, Z=2:3:4 U3 V4, Extruder 5
    M350 X16 Y16 Z16:16:16 U16 V16 I1 ; Configure microstepping with interpolation
    M350 E8 ; Set Extruder to 8x Microstepping with no interpolation
    M92 X80 Y80 Z400:400:400 U400 V400 E1900 ; Set steps per mm 2149.14
    M566 X60 Y60 Z20:20:20 U20 V20 E6 ; Set maximum instantaneous speed changes (mm/min)
    M203 X10000 Y10000 Z800:800:800 U800 V800 E3600 ; Set maximum speeds (mm/min)
    M201 X3000 Y3000 Z250:250:250 U250 V250 E120 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1850:1850:1850 U1850 V1850 E600 I75 ; Set motor currents (mA) and motor idle factor in %
    You will see that I had to put the U and V values in for each axis as in theory they are another axis that is then bound with the M584 command.
  • @samlogan87
    thanks sam.
    that also looks like a workaround like mine.
    what is your output of the M906 command?
  • @veti Aren't you missing to explicitly assign the motor of your extruder / E:3 in your M584 command, to remove the 4 from its default assignment ?
    Assigning a drive using M584 does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
  • Hi @Veti
    My M906 command is there
    Regards,
    Sam
  • @scachi
    thanks that was it.
    @veti said in Multiple independent Z motors and Motor current:
    @scachi
    thanks that was it.
    ...which is why there is that bold text in the description of M584 on the GCodes wiki page.
  • yes sometimes you need another pair of eyes to double check your config
