    Marking threads as solved
      Hi all,
      For those of you posting threads about problems you want help with, when the problem is solved to your satisfaction please can you add [SOLVED] to the end of the title. It helps others to know where to look for a potential solution, and it allows us to prioritise reading other threads.
      I've taken the liberty of adding [SOLVED] to the titles of users threads where they have indicated that the problem is solved.
      If you change your mind about whether the problem is solved, or you think I got it wrong, feel free to delete [SOLVED] from the title and add a new post to the thread.
      • Alexander Mundyundefined
        Alexander Mundy
        Is there a way to do that on the mobile version? If there is, I didn't find it.
        • T3P3Tonyundefined
          T3P3Tony administrators @Alexander Mundy
          @alexander-mundy you can edit your post, including the title. Least you should be able to.
          www.duet3d.com
            Alexander Mundy
            Now I feel stupid, was looking for an edit title. It's at the top when doing a regular edit. Thanks.
              We're hoping to add a "Mark as solved" button in the future; but for now you have to edit the title.
              • Blaiddundefined
                Blaidd
                Sorry to necro this post, it's the only one I found so far about marking threads "solved". I attempted to do this, and got an error message that a post can not be edited after 3600 seconds. That's 1 hour... not exactly very long.
                  To mark a post as solved:
                  • Go to the Topic Tools menu, which you will find on the first and last posts of the topic
                  • Select "Ask as question". It will then shows an "Unsolved" flag.
                  • Go to Topic Tools again, and select "Mark as solved".
