    Per filament Pressure Advance settings [SOLVED]
    • brunofporto
      brunofporto last edited by brunofporto
      After carefully calibrate Pressure Advance using this nice Python script I ended with a value of 1.0. That worked fine for PETG but when I came back to my usual ABS it seems to be too high.
      I remember reading at some post around here how to configure the pressure Advance per filament but I could not find it where. I already use the filament system, identifying the loaded one at the tool.
      So, please, how do I add PA configs specific to filament type?
      Thank you very much.
      Bruno Porto
        You can edit the filament load macro to include the custom pressure advance value. The filament loading system also now has a custom config.g (right click, edit config macro) that is seperate from the loading macro and will get loaded at startup as long as the filament is selected as loaded, so you can add it there as well.
        https://duet3d.dozuki.com/Wiki/Filaments
        https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Filaments
        brunofporto 1 Reply Last reply Reply Quote 0
        • brunofporto
          brunofporto @Phaedrux last edited by
          @phaedrux Thank you!
          I right clicked the filament and now there is a "config" macro option that I was not aware of 😄 That is nice and I fell dumb not noting that before.
            It's a very new feature.
