    Retraction questions
    • a96bimmerm3gmail.com
      a96bimmerm3gmail.com last edited by
      Just wanted to see what settings you guys have with deltas as far as retraction distance, coast, etc. Dialing my printer in, it's getting better but I want to make sure I have the right idea. Using the Simplify3d quality guide (and S3d as a slicer)
      (1.75mm PLA with bowden extruder)
      • burtoogle
        burtoogle last edited by
        Well, for my Kossel XL with flying extruder for PLA I am using 3mm retraction at 50mm/S retract speed, 15mm/S prime speed and 0.15mm^3 extra prime amount. 0.5mm of z-hop. Min travel of 2.5mm to trigger a retraction. I don't use coasting. Very happy with the end result. Those numbers are for Cura, I've given up with s3d.
        • Zesty_Lykle
          Zesty_Lykle last edited by
          I am using 0.8 to 1 mm retraction. Speed is between 5 and 10 mm/sec depending on the filament.
          I sometimes use a coast of 0.2 and often a hop (Retraction vertical lift) of 0.4mm
          But then I am using a remote direct drive on my Delta.
          Lykle
          Design, make and enjoy life
          Co Creator of the Zesty Nimble
            The amount of retraction you need depends on the length of the Bowden tube. With no Bowden tube, 1mm is probably enough. Otherwise I find about 1% of the Bowden tube length + 1mm about right, using 1.75,mm PLA. I set the retraction speed high, typically 3600mm/min.
