    Updating to DuetWiFi Server 1.03 Problem
    Firmware installation
    2073
    • Loffy770
      Loffy770 last edited by
      I have updated my FW in the wrong order… with Webcontrol 1.14a first but I have sorted that out with backup option 3 and now have FW 1.17c installed along with 1.14a and WiFiserver 1.02. Things seems to work fine and I can access the webinterface.
      Now to the problem.. I have uploaded the DuetWiFiserver-1.03-ch.bin and I get the green ok for the upload so it looks like the upload has gone through. But now when I check software information it still say 1.02 for the Wifi server and I have done resets and pulled power with no change.. Also updated a couple of times with the same results.. still 1.02.
      Can anyone point me to a instruction for how to fix this?
      Thanks
      Roger
      • Loffy770
        Now I cant access the board at all over web. I can connect over repetier-host so its not dead but the webserver is inaccessable.
        Help please 😉
        • T3P3Tony
          Try the following:
          Copy the new "DuetWiFiServer.bin" file to your SD card in the /sys directory. Ensure its called that and not DuetWiFiServer-1.03-ch.bin" or something like that.
          Put the SD card back in the Duet wifi, power back on and connect via USB using pronterface/repetier.
          Send the G-code M997 S1
          That will update the WifiServer firmware.
          Rboot the Duet once that is complete.
          www.duet3d.com
          • Loffy770
            15:51:13.142 : N18 M997 S195
            15:51:15.404 : N19 M105
            31
            15:51:55.449 : Communication timeout - reset send buffer block
            Cant send any commands to the card… tested to reboot But it still connects through the com port but does not take any commands.
            Is there a way to do a hard reset and start from scratch..?
            Allaready done the erase and new fw upload without any luck.
            • Loffy770
              In the device manager it shows up a Bossa Program Port.
              • T3P3Tony
                Ok looks like you erased the main firmware so go through the installing the main firmware using backup method #3:
                https://duet3d.com/wiki/Updating_main_firmware
                that will allow you to communicate again using Repetier/printerface over USB. Then carryout the instructions I laid out above. not you have to copy the DuetWiFiServer.bin file to the /sys directory by taking the SD card out of your Duet and putting it into your PC.
                www.duet3d.com
                • Loffy770
                  Okay, got in to it but now it looks like this.. So not to screw things up I will wait for your next step instructions.
                  Software Information
                  Firmware Name:
                  n/a
                  Firmware Version:
                  n/a
                  Web Interface Version:
                  1.14a
                  Web Interface by Christian Hammacher
                  Licensed under the terms of the GPL v2
                  • Loffy770
                    Well I was to quick, below is the status now, can I update the WiFiserver now?
                    Firmware Name: RepRapFirmware for Duet WiFi
                    Firmware Electronics: Duet WiFi 1.0
                    Firmware Version: 1.17c (2017-01-14)
                    WiFi Server Version: 1.02
                    Web Interface Version: 1.14a
                    • Loffy770
                      Did upgrade and it works now
                      WiFi Server Version: 1.03 (ch fork)
                      • Loffy770
                        Will read the instructions in detail next time 😄
                        Thanks for the help
                        • T3P3Tony
                          Cheers, don't worry you are not the first person who had this issue. I have a feature request to release firmware and a bundle and then the normal process would be to upload the bundle and all 3 files are updated in the right order:
                          https://www.duet3d.com/forum/thread.php?id=732
                          www.duet3d.com
                          • Alexander Mundy
                            Alexander Mundy last edited by
                            @T3P3Tony:
                            Try the following:
                            Thank you so much for this post! Your comment "Ensure its called that and not DuetWiFiServer-1.03-ch.bin" or something like that." was the thing I was missing. I pulled my hair out going through the update procedures many times without doing this critical renaming and wondering why it didn't work. This statement should be made on the Wiki pages about updating firmware for knuckle heads like me.
                            • hairy_kiwi
                              hairy_kiwi last edited by
                              @Alexander:
                              I feel your hair loss - and very much agree. It would also be very useful for this instruction to be added to the Install section of the README.MD file of RRF and DWC - to be sure to be sure. I went around in at least a couple of circles earlier today with a self-built DWC, forgetting I needed to do this, despite only doing an entire firmware update just last week.
                              • interwebsdesigner
                                interwebsdesigner last edited by
                                I know this is an old post but I seem to be having the same exact issue. I erased my board, uploaded the firmware and now getting the timeout mentioned above.
                                Could you confirm these are the correct steps.
                                1. Flash FW with sam-ba (to which i can connect to repetier after this install but get timeout)
                                2. Upload server & web to /sys and run install gcode
                                The issue I seem to be having is that my gcodes aren't executing when I send over after #1…. any thoughts?
                                  Please explain what you mean by "timeout" - what message are you getting, where, and what do you do to provoke it? If the message is from Repetier host then you should adjust the communications protocol, in particular, turn off "ping pong".
