    Unsolved Question about M106
    1110
    • fcwilt
      fcwilt last edited by
      The online documentation for M106 says that the speed can be set using 0 to 255 or 0.0 to 1.0.
      This does not appear to be true for the firmware I am currently using when controlling a fan connected to a Duex5 v0.7 board.
      Only 0.00 to 1.00 seems to work.
      Is this correct?
        0 to 255 should work as well. Values of 1.0 or lower are assumed to be in the range 0 to 1, values above 1 are assumed to be in the range 0 to 255.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @dc42 last edited by
          @dc42 said in Question about M106:
          I just tested it again with LEDs as it is a bit easier to view the result
          0 by itself does turn the LEDs off BUT 1 to 255 all seem to be the same - full on.
          0.00 to 1.00 does yield varying light levels.
          The slider in DWC confirms this.
          Is the number in the 2nd decimal place (x.x#) intended to change the speed/level by 1%?
          I cannot be sure that I am seeing such a small change in the light level.
          Thanks.
            The resolution depends on the PWM frequency you have set. It's usually well below 1%.
            What commands are you sending to adjust the PWM?
            • fcwilt
              According to the docs the FAN outputs on the Duex5 v0.7 do not have adjustable frequency.
              To test M106 I have tried:
              M106 P6 S0.0 - LEDs are off - DWC slider = 0%
              M106 P6 S0.5 - LEDS are medium - DWC slider is 50%
              M106 P6 S1.0 - LEDS are max - DWC slider is 100%
              M106 P6 0 - LEDs are off - DWC slider is 0%
              M106 P6 2 - LEDS are max - DWC slider is 100%
              M106 P6 255 - LEDS are max - DWC slider is 100%
                OK, you are using fans on the DueX board. I'll re-test those, because I only tested direct-connect fans in my recent tests.
                  I found there is a problem using values in the range 2-255 if you have other parameters in the M106 command. For example, M101 P6 S128 sets the fan to half PWM; but M106 P6 S128 F100 sets it to full PWM. I will fix this in the next 2.02RC.
                  • fcwilt
                    Thanks for the feedback.
                    But what you found does not match what I found, at least with it comes to a Duex5 v0.7.
                    No extra parameters had to be present for the S1 through S254 values to cause the setting (according to the DWC slider) to be 100%.
                      dc42 administrators @fcwilt last edited by
                      @fcwilt said in Question about M106:
                      I was unable to reproduce that, it worked perfectly for me provided that the only parameters to the M106 command were P and S.
                      fcwilt 2 Replies Last reply Reply Quote 0
                      • fcwilt
                        I will check it again.
                        • fcwilt
                          Well I went back and tested it and it now works - values from 1 to 255 have the expected effect.
                          Under any conditions does the firmware "remember" that extra parameters were used at one point and apply them for subsequent commands that have only P and S?
                            No, it doesn't.
                            • fcwilt
                              No, it doesn't.
                              Then I will just have to keep an eye on the problem and see if it reappears and under what circumstances.
                              Thanks.
