    Tool Free Macro not Working
    tool change tool selection tools tool multimaterial dualcolor dual material dual extruder filament
    1173
    • wcj97
      wcj97 last edited by
      So I’ve been working on a multimaterial system for my large format printer for a couple months now. I’m finally at a point where I can start doing a little testing, but I’ve been having issues with my TFreeX.g macros.
      My system is setup similarly to the Prusa MMU2.0. I’m using my second extruder drive as a feeder/extruder which feeds a filament to the print head. I could potentially have as many filaments loaded as my slicer will handle, or as many as I can fit on my printer. After the selected material has been fed, the main extruder takes over as a direct drive extruder. So there’s only one heating element, fan, extruder, etc.
      My TPreX.g and my TPostX.g seem to work fine, but when I run my TFreeX.g macros it skips some very important part of the macros. I’m not sure why. I’m curious if the problem lies in the fact that I have multiple tools defined to use the same heater and extruder.
      I’m not in a good place to post my macros right now, but later today I will try to include them here so everyone can see what’s supposed to happen.
      Original Prusa i3 MK2
      Hephaestus (Custom Duet based large format FFF)
      Aeon (Custom belt printer)
      Elegoo Mars
      • fma
        fma last edited by fma
        I'm also working on such filament mux, with multiple tools using the same heater, and I didn't have this problem. Could you share your tfree macro, and tell us what commands are skipped?
        Frédéric
        wcj97 1 Reply Last reply Reply Quote 1
        • wcj97
          wcj97 @fma last edited by
          @fma 2_1543699733866_tpre0.g 1_1543699733866_tpost0.g 0_1543699733865_tfree0.g
          Here are my tfree, tpost, and tpre files. The files for my other tools are the same with adjusted x coordinates.
          ; tfree0.g
          ; called when tool 0 is freed
          G0 X164.5 Y55 ; Bring print head to front of tool 0 position
          G1 F250 E-50 ; Retract filament from print head
          G1 F300 Y28 ; Apply pressure to filament
          G1 F1500 E-900:-900 ; Retract filament to filament selector
          G0 Y33 ; Release pressure on filament
          G1 F6000 Y55 ; Move print head away from filament selector
          The TFree file skips pretty much everything between The first line of gcode and the last. Instead of moving in to activate the filament selector, retracting the filament, and moving back, the print head moves in, and then immediately moves back. It's just skillping all of the traction moves.
          Just a note, my printer is configured to use relative extrusion.
          Elegoo Mars
          • fma
            Is your heater at the correct temp? How did you define your heaters and tools?
            Frédéric
            wcj97 1 Reply Last reply Reply Quote 0
            • wcj97
              @fma each tool is defined to use the same heater. It would make sense that if my temp wasn’t reached then it would skip the extrusion moves, but my TPost macros work fine. Each extrusion move works as intended. It’s just the TFree I have issues with. Also, wouldn’t that throw an error statement? When i try to just make a normal extrusion move I get an error if my temp is too low.
              Elegoo Mars
                This line:
                will only work if the tool has been configured as a 2-filament mixing extruder.
                • wcj97
                  wcj97 @dc42 last edited by wcj97
                  @dc42 the tools are set to use both extruders. One motor is my true extrusion motor, the other is a separate feed motor that feeds the filament up a Bowden tube to the main extruder. The TPost macro uses similar commands and both motors are driven without issue.
                  Elegoo Mars
                    dc42 administrators @wcj97 last edited by dc42
                    @wcj97 said in Tool Free Macro not Working:
                    ; tfree0.g
                    Can you try to pin this down? Is the problem that commands to move the extruder are not working in tfree? Are any error messages produced?
                    You can and should put M83 in your tfree.g file, before any G1 E commands. The absolute/relative extrusion state will be restored when the macro completes.
                    • wcj97
                      @dc42 I will upload a video this weekend of the material change in process, so that everyone can see where the issue lies and better understand how the mechanical side of my filament selector works.
                      On another note, Thank you for always being so attentive to this forum! I don’t think I’ve ever posed a question that you didn’t have some input on. I really appreciate that!
                      Elegoo Mars
