Dead Duet Wifi
The following is a subset of reported failure causes, selected randomly from the full set in order to not release sales volumes.
Duet Wifi Incomplete soldering
Duet Wifi Failed PS_ON functionality
Duet Wifi Flaky bootup
Duet Wifi Dead stepper driver
Duet Wifi FAN0 is dead
Duet Wifi Intermittently bad SPI comms - cannot update firmwareSome of these (incomplete soldering, SPI comms, flaky boot up) are manufacturing problems.
Some of them (dead stepper driver, fan 0 is dead) are user error, for example not understanding the thermostatic functionality of the fan channel - but that was not discovered until after the warranty exchange. Now we know to ask about that when troubleshooting
Failed PS_ON functionality - not sure what caused that.
Looking through the full set of failure data, I don't think any, with the possible exception of the dead stepper drivers, could be the result of a voltage spike. Protection is always a balance of cost vs predicted failure rate. If adding protection would increase board cost by $3 but only 0.5% of users would have experienced that damage, it doesn't make sense to implement on a ~$200 product.
With all that said, it would be nice to see Vin reverse polarity and overcurrect protection on the next revision, and I've requested as such to T3P3. Would also be nice to see input protection (inline resistor + diodes), space permitting.
Yeah, it's always a balancing act. I think that 0.5% could be mitigated through some education. Forums like this certainly help.
Jeff
A little more information about protection on the Duet WiFi.
We increased the protection on the Duet WiFi compared to the Duet 085. So far we have no indication that voltage spikes have caused any Duet WiFi failures, with two exceptions:
A couple of people connected brushed DC motors to fan outputs (e.g. Berd Air) and didn't connect a flyback diode across the motor (in fairness, at that time we didn't tell then that they needed to). This caused the fan mosfet to fail because of the spike due to the back EMF from the inductive load. Had we realised that some people would connect brushed DC motors, or seen this problem occur with the Duet 085, we would have included flyback diodes on the board for the fan outputs. We'll be adding them at the next PCB revision.
If stepper motors are disconnected under load, this produces very large voltage spikes that can blow the stepper drivers. I'll be looking at whether we can protect against this in future version of the Duet. I know that there are some very expensive external drivers that incorporate such protection. RAMBO boards attempt to provide this type of protection, but I've still seen complaints about blown drivers on RAMBO boards so I guess the protection they added isn't 100% effective. I have a feeling that providing 100% protection would require some inductors to be put in the circuit, which would be expensive and require a larger board to accommodate them.
We have ZERO evidence that ESD has caused any Duet WiFi failures. So I'm far from convinced that TVS diodes would contribute anything to reliability. It's very easy to add protection devices without any evidence that they solve a problem. OTOH we know from experience with the Duet 06 and 085 that shorts between heaters and thermistors (causing 12V or 24V to be fed into the thermistor inputs) are very common, which is why we designed the Duet WiFi to survive those - at the expense of the VSSA fuse in some cases.
It's also possible for the user to connect VIN with reverse polarity. Some boards attempt to provide protection against this, using either a fuse and crowbar diode, or (in the case of Smoothieboard) a P-channel mosfet. I'm not convinced that the crowbar diode will give full protection - the voltage drop across it before the fuse blows may still allow too much current to flow through the stepper drivers to damage them. The circuit used on Smoothieboard should protect better, but needs more space and increases cost. However, I have never heard of anyone applying reverse VIN power to a Duet, so it doesn't appear to be a significant risk and we didn't include that type of protection. I guess it's possible that a few people have reversed the VIN polarity but been too embarrassed to admit it!
I don't think reverse protection is really needed. Kind of one of those don't drink and assemble rules.
I think it's time for you to ask your supplier for a replacement under warranty.
When I inquired with the supplier, they weren't sure about the warranty or replacement policy and had sent a note to T3P3. If you can point me to an official warranty policy that'd be appreciated.
I've already purchased a replacement board and had it overnighted, as I had not heard back yet on my inquiry with the supplier and needed to get the machine back up and running. Since we weren't able to identify the cause of the failure, I still assume it could've been something I did, in which case I have no problem with paying for a replacement. Either way, I'd be happy to ship my dead board back for analysis if it might reveal the cause or help improve future products.
Please email info@duet3d.com with more details (I.e. who the supplier is, the failure stuff is well documented in this thread). We will certainly want the original board back for investigation however normally this will be arranged as part of the warranty replacement process.
I (Filastruder) was the supplier, Roland was CCed on an email last night. The only oddball items is that the board was delivered back in September as part of the pre-order.
Hi Tim, sorry I missed that. Thanks for clarifying quickly!
cchaffee, ignore my previous comment, Tim is all over this.
Great, thanks guys. I will stand by and await further instructions.
