    Dual Z Wiring
    • hevilp
      hevilp last edited by
      I got a HEVO running, but now I want to use 2 endstops, each for every z motor.
      Do I move the second z motor to E0 motor connector? (so z motor 2 on E0 and endstop at E0)
      Or just connect the endstop to the E0 endstop and the Z motor stays at the second z connector?
      If yes, the E0 moves to E1?
      Thanks
        dc42 administrators @hevilp last edited by
        @hevilp said in Dual Z Wiring:
        Yes. You will need to define the second Z motor as the U axis while Z homing. There are other threads on this forum about how to do this.
        • thwe
          thwe last edited by
          I will show you, how i have done it - and i hope everything is done well:
          the wiring diagram:
          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
          My config.g
          0_1542973940030_config.g
          ... and here the homez.g:
          0_1542974052538_homez.g
          Thomas
          • hevilp
            hevilp last edited by hevilp
            @thwe
            thanks, your code is working
            I think the M400 is needed, the code from
            https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en
            does not work, the Z switch never gets touched (E0 is touched). If I touch him manually bad Z value comes out(very high).
            With M400 is works!
            Thanks!
            • irondesk40
              irondesk40 last edited by
              Now this has been very helpful. Great post with actual wiring diagram attached and G code. Plan to take this home this weekend and print out the G code and search G code commands and get a better understanding of exactly what each line of code is doing (New to G Code), background is PLC and Automation but really getting interested in learning this.
              • irondesk40
                Actually this kind of post helps folks decide which product to use. Have not had a chance to hook anything up yet, just got the parts and leaving for a few days but have researched a lot of others and asked questions on the forum and sent emails and this one is by far the best.
                • thwe
                  thwe last edited by
                  Thanks, but please note:
                  All Parameters in the files (such as axle limits, accelerations, directions of rotation, etc.) are not final yet, as my printer is currently learning how to walk - and similar to children, at the moment it's still stumbling 🙂
                  Thomas
