    SOLVED Ender 3 settings?
    My Duet controlled machine
    ender3 json settings
    8
    11
    4722
    • 3dmntbighker
      3dmntbighker last edited by
      Can anyone provide me with the baseline settings for speeds and etc. for an Ender 3? I'm not sure how many people have installed the Duet on one. I guess I could find the settings in the Marlin code from GitHub, but I was hoping someone had the Duet settings handy to just copy/paste. Or even the JSON file would work. Mine is working, but I'm not sure how well it's optimized.
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • DocTrucker
        DocTrucker last edited by
        I think the firmware they use is marlin based so if you have no joy with an easy reply on here you should at least be able to find the default acceleration, instantaneous speed, max speed etc from there.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
          Here's a video series where the Ender3 is upgraded with a DuetWifi. He goes into a lot of step by step detail.
          https://www.youtube.com/watch?v=RmZ7aJYvWLc&list=PLtVk4dZInT80SCVB_Pgrn1zZThO3nmV7B&index=2
          And here's some basics on adapting an existing printer to use the Duet. https://duet3d.dozuki.com/Wiki/Going_from_Marlin_on_Arduino_to_RepRapFirmware_on_Duet
          That might get you started.
          3dmntbighker 1 Reply Last reply Reply Quote 3
          • Wyvern
            Wyvern last edited by
            On my FT-5 I got my baseline from writing down the marlin settings, then used the RRF config tool to plug them in.
            Also note instantaneous speed is "Jerk".
            When you use the RRF tool it will also put notes in the G-code files.
            • 3dmntbighker
              3dmntbighker @Phaedrux last edited by
              @phaedrux said in Ender 3 settings?:
              Thanks, yeah, he pulled the settings from the Creality open source Marlin file.
              • A Former User
                A Former User last edited by
                i have a duet wifi on a ender 3
                what do you need ?
                3dmntbighker nawjesh mrplay1234 3 Replies Last reply Reply Quote 0
                • 3dmntbighker
                  3dmntbighker @Guest last edited by
                  @calvinx said in Ender 3 settings?:
                  what do you need ?
                  I got the stuff from the Marlin Creality file on Github. I increased most of my max speeds.
                  • nawjesh
                    nawjesh @Guest last edited by
                    @calvinx
                    Hi, i have duet2 wifi installed in my Ender3 . everything is working except nun of my fan is working. Is it possible for you to send me your config file or any advice on it. thanks.
                    • mrplay1234
                      mrplay1234 @Guest last edited by
                      what do you need ?
                      Can you post your config.g please....?
                      Just need to check a few things
                      • A Former User
                        Hi
                        I am afraid I am not in a position to do that. I previously posted my operational heater settings for the ender 3 and dc42 advised that they were incorrect. Even though they work fine for me.
                        Therefore It would be wrong of me to post my operational settings for the fear of them being picked apart and I wouldn't wish to inadvertently cause anyone else to have an issue with their machine because they used any settings of mine, which might or might not be correct.
                        I hope you understand my position.
                        Best Regards
                          @CaLviNx, if you post your settings then I can make suggestions if I think they should be changed.
