    Precision Piezo for E3D V6 Threaded Heatsink
    Third-party add-ons
    2505
    • rikesh942018
      rikesh942018 last edited by
      I have been using the Mini IR Sensor for the machine that I have been developing (Company printer) unfortunately when the machine was sent for user testing, there were few issues with PEI surface on aluminium (I knew this was going to be a problem but I didn't think it was going to be a big issue). Out of 4 sensors 2 had several problems after few days of printing.
      As much as I love the IR Sensors and will continue to use them for personal use I am now looking for a different sensor for the company printers.
      I wanted to know if anyone has tried the Precision Piezo Sensor on the E3D Threaded Heatsink design:
      https://e3d-online.com/v6-threaded-heatsink
      Just so people get a better idea, the design looks like this: 0_1543688199221_Capture213123123213.JPG
      The threaded heatsink is attached using a M12 nut between a milled aluminum bracket, I want to avoid modifying this too much but I am not sure if it is even possible to attach a Piezo sensor to this.
      I know Dc42 has a design for delta machines that use this heatsink and some type of contact sensor but could not find any more information on the actual sensor or how its attached to this heatsink 😞
      Any help is appreciated, Thanks guys
        dc42 administrators @rikesh942018 last edited by
        @rikesh942018 said in Precision Piezo for E3D V6 Threaded Heatsink:
        See https://www.duet3d.com/DuetAddons/DeltaSmartEffector and https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer for the details.
        rikesh942018 1 Reply Last reply Reply Quote 0
        • rikesh942018
          rikesh942018 @dc42 last edited by
          I had a look at this earlier before posting this, I should have specified that the machine is a Corexy and not a Delta. I have been trying to search for how you have implemented the contact sensor with the heatsink but wasn't able to find much information. Is there any chance you are planning on developing something like this for a Cartesian system.
          • Dougal1957
            Dougal1957 last edited by
            you could also have a look at this thread link text
            • rikesh942018
              rikesh942018 @Dougal1957 last edited by
              @dougal1957 Thank you so much, I never saw that page
              • Moriquendi
                Moriquendi last edited by
                I have a threaded heatsink and it should be trivial to design a mount for it and the Orion. The only reason I haven't done it yet is that nobody's asked for it and as far as I can see the uptake of threaded heatsink has not been huge. Give me a day or two and I'll see what I can come up with.
                Idris
                • rikesh942018
                  rikesh942018 @Moriquendi last edited by
                  @moriquendi
                  Well if you can design a mount for it, I would be happy to purchase the Orion module for testing, ideally later I would try to incorporate the design to work with my aluminium milled part.
                  • zzing
                    zzing last edited by
                    I have actually just done this with a mini kossel that I am retrofitting. It does not use the smart effector, but one of my own design. It is presently in pieces awaiting linear rails however.
                    • rikesh942018
                      rikesh942018 @zzing last edited by
                      @zzing said in Precision Piezo for E3D V6 Threaded Heatsink:
                      Mind sharing the design? I can try to look into adapting the design for my machine.
                      zzing 1 Reply Last reply Reply Quote 0
                      • Moriquendi
                        First prototype mount for the threaded heatsink. Print with 0.2mm layer height.
                        Idris
                        rikesh942018 Dougal1957 3 Replies Last reply Reply Quote 0
                        • rikesh942018
                          @moriquendi said in Precision Piezo for E3D V6 Threaded Heatsink:
                          Idris
                          Thanks for the quick design, you have a new buyer for the Orion Module
                          • Dougal1957
                            Dougal1957 @Moriquendi last edited by
                            @moriquendi Idris If you remember I asked about this some time ago but I was more interested in a bare pub that would take the threaded heatsink however this solution may well work for me. Do you have a render showing how it all fits together?
                            Doug
                            • Moriquendi
                              I don't think (at the moment) that there's sufficient market for a PCB specifically for the threaded heatsink though hopefully that will change, the groove mount is... suboptimal.
                              This however involves much less investment.
                              0_1543949272026_Orion v6 Threaded 2.jpg 0_1543949015924_Orion v6 Threaded 1.jpg
                              Green is the new part specific to the threaded heatsink.
                              Blue is a standard Orion top piece, either screwmount (shown) or threaded or a custom part.
                              Purple is the Orion PCB.
                              Idris
                              Dougal1957 1 Reply Last reply Reply Quote 0
                              • Dougal1957
                                @moriquendi ah so the thread it integral to the mount then?
                                • Moriquendi
                                  Yes, it's actually very secure even when tightened by hand.
                                  • Dougal1957
                                    Dougal1957 @Moriquendi last edited by Dougal1957
                                    @moriquendi how about in a heated chamber tho?
                                    May well print one and check it out tho and order a orion to see how it works out.
                                    • Moriquendi
                                      I think that you would be able to print a mount in nylon or some other material that would hold up in a heated chamber up to the temperature where the piezos would become unreliable anyway (somewhere around 80c I would expect)
                                      Idris
                                      • zzing
                                        zzing @rikesh942018 last edited by
                                        @rikesh942018 https://www.thingiverse.com/thing:3262683
                                        • rikesh942018
                                          @zzing Thanks for uploading this
                                          • rikesh942018
                                            @Moriquendi
                                            Would you be able to upload a STEP file please.
                                            Moriquendi 1 Reply Last reply Reply Quote 0
                                            • Moriquendi
                                              Moriquendi @rikesh942018 last edited by
                                              @rikesh942018 I've just uploaded the step file to thingiverse, follow the link above.
                                              Idris
                                              • Dougal1957
                                                I sent the file to Shapeways and expecting the print later today in SLS printed Nylon should be ok I hope.
                                                • rikesh942018
                                                  @moriquendi
                                                  Perfect, Thanks 😄
                                                  • Dougal1957
                                                    The Shapeways part is spot on not the cheapest way but it is at least in Nylon at very low layer lights and 100% infill so should be quite strong and stable. cost was about £12 and took 5-6 days from upload to delivery
                                                    will order the Orion module a bit later Idris in no real rush for it!
                                                    Doug
                                                    • Moriquendi
                                                      Just a heads up: I wont be dispatching anything between 21/12/18 and 3/1/19
                                                      Idris
